- create a vlan interface
- assign a IP address to VLAN interface
- ping this IP address. BUT no any response.
Why I can’t ping this IP address?
If you are using a master port, vlan must be taken from the master port.
you are sure that the VLAN to mikrotik comes.?
Thank you for your reply!
I use ether4-slave-local port, and connected to the trunk port on switch.
BUT this router can’t not decapsulate vlan tag, am I right?
How could I setting the interface like trunk port?
