Hello
Dear all,
I couldn’t enable or find RoMON button
No RoMON Help Please
Go into settings (upper right corner) and there you’ll find a toggle “Enable RoMON”
thanks for your answer.
But it’s only available in the Android not in the iPhone.
Any Mikrotik team member please look in this matter
Still no option for Enable RoMoN in iphone Mikrotik App
Best to shoot ticket to support.
MT staff doesn’t read all posts on this forum (since this is a user forum).
Worth a feature request ticket. But… I’m not even sure RoMON is possible under Apple iOS.
The iOS SDK deals with URL fetching or opening TCP/UDP sockets.. so Layer2 RoMON with it’s non-IP ether-type likely poses a problem since iOS doesn’t just allow raw Layer2 access to the network interface - everything goes through an Apple’s APIs. Perhaps some entitlement that might allow it (like VPN), but it be technically difficult or perhaps impossible.
How to shoot ticket to support?
https://help.mikrotik.com - create request, and one of the choices is “feature request”.
