Hi all,
I have a MikroTik CRS312-4C+8XG and I am trying to configure it as a router to connect to my ISP’s router. The ISP’s router is a Virgin Media Hub 4 which has been placed into modem mode. With the config shown below there are a few things that work and things that do not work…
- The modem and router communicate okay as I can see that the DHCP client gets an ip, gateway, dhcp server and dns server.
- From a Mikrotik terminal I can ping 8.8.8.8 and a fqdn.
- From a PC on the LAN side I can ping the public assigned ip address on ether1 (WAN) and all other devices connected in the LAN.
- From a PC on the LAN side I cannot ping anything on the internet, e.g. 8.8.8.8, including the WAN gateway ip address.
- The DHCP server on the LAN side only gives its clients an ip address but does not give it the gateway ip. I assume that this should be 192.168.0.1
- If I set a PC’s ip address manually to, say, 192.168.0.8, gateway to 192.168.0.1 and dns to 8.8.8.8,8.8.4.4 I still cannot ping anything on the internet.
I see two issues here:
There is no route between LAN and WAN.
DHCP server on LAN side is not giving its clients the gateway ip address.
I have tried to enable/disable ip-forward, turning off all the firewall rules and disabling the LAN DHCP server but still no luck.
Any help here would be very much appreciated.
Mark
The config:
# apr/09/2022 19:17:00 by RouterOS 7.2
# model = CRS312-4C+8XG
add name=BRIDGE
/interface ethernet switch
set 0 l3-hw-offloading=yes
add name=WAN
add name=LAN
add name=POOL_MAIN ranges=192.168.0.50-192.168.0.254
add address-pool=POOL_MAIN interface=BRIDGE name=DHCP_MAIN
/port
set 0 name=serial0
add bridge=BRIDGE comment=defconf interface=combo1
add bridge=BRIDGE comment=defconf interface=combo3
add bridge=BRIDGE comment=defconf interface=combo4
add bridge=BRIDGE comment=defconf interface=ether2
add bridge=BRIDGE comment=defconf interface=ether3
add bridge=BRIDGE comment=defconf interface=ether4
add bridge=BRIDGE comment=defconf interface=ether5
add bridge=BRIDGE comment=defconf interface=ether6
add bridge=BRIDGE comment=defconf interface=ether7
add bridge=BRIDGE comment=defconf interface=ether8
add bridge=BRIDGE comment=defconf interface=ether9
add bridge=BRIDGE comment=defconf interface=combo2
/ip settings
set ip-forward=yes
add interface=ether1 list=WAN
add interface=BRIDGE list=LAN
add address=192.168.0.1/24 interface=BRIDGE network=192.168.0.0
/ip dhcp-client
add address=192.168.0.0/24 dns-server=9.9.9.9 gateway=192.168.0.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN src-address=192.168.0.0/24
/ip ipsec policy
set 0 disabled=yes
add dst-address=0.0.0.0/0 src-address=0.0.0.0/0 template=yes
