i installed the RouterOS on a x86. Then i boot the pc and the login pop’s up. As user admin and the password left clear. Then the banner comes up an there is the Software ID und the banner. It tells that i must order a key. I ordered a demo key. But when i press Enter i return to the Login and this on and on. How can i get a shell on the device or how can i enter the key ?
best regards
frapzzt
something went wrong with your install. try to reinstall. the command line must appear below the initial message
okay i reinstalled ist several times. one time minimal one time with system ppp dhcp an many other combinations. but it is the same failure
push
can you try it on another machine? use the same HDD. maybe an incompatibility issue
no the hd is plugged on the board
huh? how is that? maybe you have some sort of specific machine, that’s why it doesn’t work. what hardware is that?
it is an old dsa-3100 made by dlink.
I wonder how it works at all. Well in any case, you should use something that’s officially compatible.
http://www.mikrotik.com/testdocs/ros/2.9/guide/driverlist.php
