No 'Shift + F3'
I have more than 500 entries in my hotspot, each one with comments. When I use the FIND textbox in Winbox, I would like to jump from one hit to the other by pressing Shift F3 or something like that. The reversed grey mark isn’t as comfortable as jumping from one hit to the oher…
Is there a way?
the standard combination ctrl+g works
Thank you, Normis!!!
To me, the standard was shift+F3, but I obviously know nothing…
Thanks again, you’re really helpful!
Chofex
