"No such item (4)" while counting connections
Hello!
Please help me understand why I get “no such item” error in this code:
[admin1@MT1] > /ip firewall connection print count-only where dst-address~"1.1.1.1|2.2.2.2|3.3.3.3|4.4.4.4|5.5.5.5"
212
no such item (4)
413
268
no such item (4)
413
/ip firewall connection print count-only where dst-address~"[1-5]+\\.[1-5]+\\.[1-5]+\\.[1-5]+"
OR
/ip firewall connection print count-only where (dst-address~"1.1.1.1" || dst-address~"2.2.2.2" || dst-address~"3.3.3.3" || dst-address~"4.4.4.4" || dst-address~"5.5.5.5")
Thanks for your explanation, but it does not solve the problem.
In fact, I get “no such item” error even without using logical operations and searching for a single IP address.
[admin1@MT1] > /ip firewall connection print count-only where dst-address="1.1.1.1"
0
no such item (4)
0
[admin1@MT1] > /ip firewall connection print count-only where dst-address~"1.1.1.1"
235
no such item (4)
436
It is interesting that the problem occurs only in about half the cases.
Also, it is related to the number of entries in the connection table.
The more entries - the higher the probability of “no such item” error.
Likely the “where” clause is walking through the connections list and while it is doing so some connections disappear.
The more users/connections you have, the more likely that probably is to occur.
This is always a problem in such “first/next” walking through lists that are not static.
Whether that should have been covered in RouterOS and handled invisibly from the users is a matter for debate…
The main problem is that this error terminates the script execution and I do not understand how to ignore this error.
Suppose I have this script:
  ... Some code ....
Getting "no such item" - Script terminating.
  ... Some code - 2 ....
The code “Some code - 2” will not be executed.
Is it possible to force ROS ignore “no such item” error and continue code execution?
You should read the manual on Scripting before attempting anything serious… because there are so many pitfalls!
https://wiki.mikrotik.com/wiki/Manual:Scripting#Catch_run-time_errors
https://wiki.mikrotik.com/wiki/Manual:Scripting_Tips_and_Tricks
Thanks for reply.
I tried do {} on-error = {}
But it did not solve my problem.
Code:
:global result
:log info ("Step1")
:do {
      :set result [/ip firewall connection print count-only where dst-address~":80"];
} on-error={:log info ("Error1")};
:log info ("Result1: $result")
:log info ("Step2")
:do {
} on-error={:log info ("Error2")};
:log info ("Result2: $result")
Result:
[admin1@MT1] >
17:15:49 echo: script,info Step1
[admin1@MT1] >
17:16:07 echo: script,error script error: no such item (4)
The script is terminated. (((
Is there something wrong with my code?
On the low-loaded Mikrotik this code is executed successfully…
I think using
:set result [:len [/ip firewall connection find where dst-address~":80"]]
is cleaner. And in my experience, for some arcane reason, avoids the non-atomic list traversal.
On Router (CRS125-24G-1S-2HnD) with 200 active connection entries:
[admin1@MikroTik] > :put [:len [/ip firewall connection find where dst-address~":80"]]
4
[admin1@MikroTik] >
On Router (CCR1036-12G-4S) with 80000 active connection entries:
[admin1@MT1] > :put [:len [/ip firewall connection find where dst-address~":80"]]
no such item (4)
[admin1@MT1] >
Any ideas?
Connection tracking is large periodically changing table. While processing entries that entry could already be removed, so you will get no such item.
That is what I expected, but why is the error not handled by do {} on-error = {} ?
Is it possible to perform a search in large periodically changing table without errors?
[admin1@MT1] > /ip firewall connection print where dst-address~":80"
Flags: E - expected, S - seen-reply, A - assured, C - confirmed, D - dying, F - fasttrack, s - srcnat, d - dstnat
 #          PROTOCOL SRC-ADDRESS           DST-ADDRESS           TCP-STATE   TIMEOUT     ORIG-RATE REPL-RATE ORIG-PACKETS REPL-PACKETS      ORIG-BYTES      REPL-BYTES
 0  SAC  s  tcp      172.16.9.21:49346     203.119.201.254:80    established 17m58s           0bps      0bps          233          244          15 214          15 212
 1  SAC     tcp      x.x.x.x:7178   162.252.21.64:80      established 19m54s           0bps      0bps          908          908          37 228          36 320
 2  SAC  s  tcp      172.16.12.110:49003   185.221.47.112:80     established 19m59s      269.0kbps  19.7Mbps    3 182 536    7 845 361     134 840 136  11 591 313 145
 3  SAC  s  tcp      172.16.8.82:41163     140.205.195.98:80     established 19m38s           0bps      0bps          188          183          12 856          12 004
 4  SAC     tcp       x.x.x.x:50112   77.234.43.26:80       established 17m6s            0bps      0bps          118          199          20 810         112 745
 5  SAC     tcp       x.x.x.x:57974  203.119.205.0:80      established 17m19s           0bps      0bps          923        1 764          73 454         108 782
 6  SAC     udp       x.x.x.x:35529   47.91.93.96:8000                  1m19s            0bps      0bps        4 310        4 297         310 320         274 768
 7  SAC     tcp       x.x.x.x:58013  47.254.151.183:8080   established 18m32s           0bps      0bps        3 088        1 739         186 779         178 340
Thats ok!
But
:put [/ip firewall connection find dst-address~":80"]
no such item (4)
WHY???
Is there another way to search the large connection table that does not cause errors?
