Something similar was mentioned in re: ROS 6.46 five years ago (see below).
On ROS 7.23.1, I occasionally will see /tool/sniffer packet print follow operations terminate abruptly with a "no such item" error, e.g.
[admin@MikroTik3] /tool/sniffer> pack print follow
TIME INTERFACE SRC-ADDRESS DST-ADDRESS IP-PROTOCOL SIZE CPU
24.657 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 282 0
24.749 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 218 0
24.749 bridge 83.40.90.106:56306 10.0.0.5:56306 udp 218 0
24.75 bridge 10.0.0.5:56306 83.40.90.106:56306 udp 122 0
24.75 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 122 0
24.755 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
24.756 bridge 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
24.874 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
24.874 bridge 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
24.875 bridge 10.0.0.5:56306 83.40.90.106:56306 udp 554 0
24.875 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 554 0
25.094 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
25.094 bridge 83.40.90.106:56306 10.0.0.5:56306 udp 122 0no such item (4)
29.559 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 1482 0
29.662 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
29.662 bridge 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
29.662 bridge 10.0.0.5:56306 83.40.90.106:56306 udp 714 0
29.662 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 714 0no such item (4)
34.588 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 1482 0
34.661 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
34.662 bridge 83.40.90.106:56306 10.0.0.5:56306 udp 122 0
34.662 bridge 10.0.0.5:56306 83.40.90.106:56306 udp 282 0
34.662 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 282 0
34.759 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 218 0
34.759 bridge 83.40.90.106:56306 10.0.0.5:56306 udp 218 0
34.76 bridge 10.0.0.5:56306 83.40.90.106:56306 udp 122 0
34.76 ether2 10.0.0.5:56306 83.40.90.106:56306 udp 122 0
34.88 ether2 83.40.90.106:56306 10.0.0.5:56306 udp 122 0no such item (4)
The current sniffer configuration while this packet print follow is in progress is:
[admin@MikroTik3] /tool/sniffer> print
only-headers: no
memory-limit: 100KiB
memory-scroll: yes
file-name:
file-limit: 1000KiB
streaming-enabled: no
streaming-server: 0.0.0.0:37008
max-packet-size: 2048
filter-stream: no
filter-interface:
filter-mac-address:
filter-src-mac-address:
filter-dst-mac-address:
filter-mac-protocol:
filter-ip-address: 10.0.0.5/32, 83.40.90.106/32
filter-src-ip-address:
filter-dst-ip-address:
filter-ipv6-address:
filter-src-ipv6-address:
filter-dst-ipv6-address:
filter-ip-protocol:
filter-port: 56306
filter-src-port:
filter-dst-port:
filter-vlan:
filter-cpu:
filter-size:
filter-direction: any
filter-operator-between-entries: and
quick-rows: 20
quick-show-frame: no
running: yes
.. so it doesn't seem that the sniffer should be looking for anything that might suddenly stop existing.
Am I missing something, or does this remain a RouterOS bug?
Post from five years ago:
