No Such Item, generated whilst trying to import config generated by unit with same firmware.
We have units generate a backup of themselves with the export file= command.
Whilst trying to import this file into another unit with the same firmware I get the uninformative ‘No Such Item’ error message.
Q1) Why do 2 separate units with the same firmware generate this message from a .rsc file that it generated itself?
Q2) Am I able to somehow find out what is causing the error to be thrown?
Thanks.
Put the file content line by line into terminal window to find what causes the message. Be sure you fully wipe the configuration before.
This may occur, for example, if you try to use non-existent certificate. You shold import certificate and/or key file before importing rsc script.
