Hi guys,
I have Version 6.41 RouterOS CHR and I have installed a TL-WN881ND which the mikrotik detects
But there is no way for me to configure it
I get no supported channel, scan list does not contain valid channels and no supported channels
I’ve added manually! the 2.4Ghz channels under channels but I have the same errors
Can somebody help?
0 ;;; no supported channel
;;; scan-list does not contain valid channels
;;; no supported channels
name=“wlan1” mtu=1500 l2mtu=1600 mac-address=18:D6:C7:28:8D:FA
arp=enabled interface-type=Atheros AR92xx mode=ap-bridge ssid=“T2-NET”
frequency=auto band=2ghz-b/g/n channel-width=20/40mhz-Ce
secondary-channel=“” scan-list=default wireless-protocol=802.11
vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default compression=no
