No traffic through forward fasttrack or forward established|related [solved]
I have an older RB1100AH that I had reset.
I put the standard fastrack connection with hardware offload and accept established related in the top of my forward firewall filter rules.
I also have the standard forward accept from LAN
And then the standard forward drop from WAN not dst-nat.
I also have the srcnat masquerade out WAN.
But strangely, I can not get any connectivity to WAN from LAN. When I try a ping, the ping goes out but I never receives the reply until I disable the last forward drop from WAN rules.
My fasttrack counter never increases, same with the accept forward established related that stays at zero.
What I am missing? Why the established/related is not detected for the returned traffic?
I checked IP settings that allow fast path is checked.
Any clue what to check?
# 2025-11-02 08:52:38 by RouterOS 7.20.2
# model = RB1100AH
/interface bridge add name=bridge_inside port-cost-mode=short
/interface ethernet set [ find default-name=ether1 ] name=eth1-internet
/interface list add name=WAN
/interface list add name=LAN
/ip pool add name=dhcp_inside ranges=192.168.50.96/27
/ip dhcp-server add address-pool=dhcp_inside interface=bridge_inside lease-time=12h name=inside
/interface bridge port add bridge=bridge_inside ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge_inside ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
/ip firewall connection tracking set udp-timeout=10s
/ipv6 settings set disable-ipv6=yes max-neighbor-entries=8192 soft-max-neighbor-entries=8191
/interface list member add interface=eth1-internet list=WAN
/interface list member add interface=bridge_inside list=LAN
/ip address add address=192.168.50.1/24 interface=bridge_inside network=192.168.50.0
/ip dhcp-client add interface=eth1-internet
/ip firewall filter add action=fasttrack-connection chain=forward connection-state=established,related connection-type="" hw-offload=yes
/ip firewall filter add action=accept chain=forward connection-state=established,related connection-type=""
/ip firewall filter add action=drop chain=forward connection-state=invalid
/ip firewall filter add action=accept chain=forward comment="dst nat from WAN" connection-nat-state=dstnat in-interface-list=WAN
/ip firewall filter add action=accept chain=forward comment="exit rule" in-interface=bridge_inside out-interface=eth1-internet
/ip firewall filter add action=accept chain=forward comment="inter LAN" in-interface=bridge_inside
/ip firewall filter add action=accept chain=forward connection-nat-state=dstnat
/ip firewall filter add action=drop chain=input connection-state=invalid
/ip firewall filter add action=accept chain=input in-interface-list=LAN
/ip firewall filter add action=accept chain=input connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input disabled=yes in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat out-interface-list=WAN
/ipv6 firewall filter add action=drop chain=forward
/ipv6 firewall filter add action=drop chain=input
/routing bfd configuration add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
Setadd-default-route=yes for the DHCP Client?
ip firewall filter
add action=accept chain=forward connection-state=established,related,untracked
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN /
    comment="internet traffic"
add action=accept chain=forward connection-nat-state=dstnat comment="port forwarding"
add action=drop chain=forward comment="drop all else"
add action=accept chain=input dst-address=127.0.0.1
add action=drop chain=input  comment="drop all else"  { put this rule here but last of all rules created }
Fix this! The field should be cleared, not set to the empty string "". In WinBox, click on the triangle up-arrow to clear the field (make it greyed out).
Do that for both the fasttrack and the accept established,related rules.
Nice catch, not the first time this kind of misconf. comes up? What’s going on here…
That did it and that makes sense… I probably went through that setting ten times without noticing it…
Thanks for the proofreading… I have set up over hundreds of Mikrotik routers from scratch and I was starting to lose my sanity.
Are there any things either misconfigured or left behind between versions?
