No useful Terminal anymore
i’m running 6.39rc12 on a RB2011.
Since some time and some updates, i wanted to use the terminal mode.
However, i end up at a “[Ctrl-A is the prefix key]” note.
Before, i remember having a full promt to navigate through the full configuration menu.
This is the same for the terminal buttons in winbox, the web interface and a SSH login.
What did i miss ?
Thanks, Jan
Ok, solved by resetting to factory defaults.
This also solved the problem, that the CPU constantly ran at 100%, which i didn’t recognize before,
but was happening since 6 weeks, which i saw in the CPU graph.
Regards, Jan
