I’m not sure if WAN access is expected to work out of the box with back to home? I cannot browse the web on my iPhone when connected via back to home.
I see one other topic with a similar problem: http://forum.mikrotik.com/t/back-to-home-works-without-internet/176207/1
But i’m not sure i see the solution to the problem in that thread, maybe i just don’t understand the answers correctly.
Here’s my config:
[myuser@MikroTik] > /export
# 2024-12-08 18:32:18 by RouterOS 7.16.2
# software id = 5TRY-6BL4
# model = RB5009UG+S+
# serial number = XXX
add admin-mac=48:A9:8A:25:99:6C auto-mac=no comment=defconf name=deco port-cost-mode=short
/interface wireguard
add comment=back-to-home-vpn listen-port=48027 mtu=1420 name=back-to-home-vpn
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.2-192.168.0.254
add address-pool=dhcp interface=deco lease-time=10m name=defconf
/ip smb users
add bridge=deco comment=defconf interface=ether2 internal-path-cost=10 path-cost=10
add bridge=deco comment=defconf interface=ether3 internal-path-cost=10 path-cost=10
add bridge=deco comment=defconf interface=ether4 internal-path-cost=10 path-cost=10
add bridge=deco comment=defconf interface=ether5 internal-path-cost=10 path-cost=10
add bridge=deco comment=defconf interface=ether6 internal-path-cost=10 path-cost=10
add bridge=deco comment=defconf interface=ether7 internal-path-cost=10 path-cost=10
add bridge=deco comment=defconf interface=ether8 internal-path-cost=10 path-cost=10
add bridge=deco comment=defconf interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=none
/ipv6 settings
set disable-ipv6=yes
add comment=defconf interface=deco list=LAN
add address=192.168.0.1/24 comment=defconf interface=deco network=192.168.0.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes ddns-update-interval=10m update-time=no
/ip cloud back-to-home-users
add allow-lan=yes comment="iPhone 12" name=RB5009UG+S+ private-key="xxx=" public-key=\
"yyy="
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.10 client-id=1:98:1:a7:99:6f:cf mac-address=98:01:A7:99:6F:CF server=defconf
add address=192.168.0.5 client-id=ff:f8:ce:1b:a1:0:2:0:0:ab:11:a3:5f:3b:bf:fe:9c:ba:7f mac-address=00:1E:06:43:D2:C0 server=defconf
add address=192.168.0.6 client-id=1:0:1e:6:32:92:2f mac-address=00:1E:06:32:92:2F server=defconf
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.1 gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.0.2-192.168.0.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=not_in_internet
add address=mydomain.net list=cloudflare
add action=accept chain=input comment="default configuration" connection-state=established,related
add action=accept chain=input src-address-list=allowed_to_router
add action=drop chain=input
add action=fasttrack-connection chain=forward comment=FastTrack connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Established, Related" connection-state=established,related
add action=drop chain=forward comment="Drop invalid" connection-state=invalid log=yes log-prefix=invalid
add action=drop chain=forward comment="Drop tries to reach not public addresses from LAN" dst-address-list=not_in_internet in-interface=\
deco log=yes log-prefix=!public_from_LAN out-interface=!deco
add action=drop chain=forward comment="Drop incoming packets that are not NATted" connection-nat-state=!dstnat connection-state=new \
in-interface=ether1 log=yes log-prefix=!NAT
add action=drop chain=forward comment="Drop incoming from internet which is not public IP" in-interface=ether1 log=yes log-prefix=\
!public src-address-list=not_in_internet
add action=drop chain=forward comment="Drop packets from LAN that do not have LAN IP" in-interface=deco log=yes log-prefix=LAN_!LAN \
src-address=!192.168.0.0/24
add action=masquerade chain=srcnat comment=Hairpin dst-address=192.168.0.0/24 src-address=192.168.0.0/24
# Some open ports left out...
/ip ipsec profile
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Copenhagen
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Any advice is appreciated, thanks in advance.
