No WAN access via Wireguard
Thank you so much @anav for looking into it, all the advices are much appreciated!
i have just updated the settings with your recommendations:
# 2024-06-10 18:03:55 by RouterOS 7.15
# software id = 63WL-9G9C
# model = RB2011UiAS-2HnD
# serial number = 467304B1DBAF
/caps-man channel
add control-channel-width=20mhz extension-channel=Ce frequency=2442 name=\
    channel2G tx-power=13
add extension-channel=Ce frequency=5180 name=channel5G tx-power=13
add admin-mac=4C:5E:0C:43:D6:3E auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
/interface wireless
# managed by CAPsMAN
# channel: 2442/20-Ce/gn(9dBm), SSID: WiFi, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=sweden distance=indoors installation=indoor mode=ap-bridge ssid=\
    "The Apartment" station-roaming=enabled wireless-protocol=802.11
/interface wireguard
add listen-port=33333 mtu=1420 name=wireguard
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes name=datapath2G
add bridge=bridge client-to-client-forwarding=yes name=datapath5G
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm,tkip \
    group-encryption=aes-ccm name="Security config 2G"
    group-encryption=aes-ccm name="Security config 5G"
/caps-man configuration
add channel=channel2G channel.band=2ghz-b/g/n country=sweden datapath=\
    datapath2G mode=ap name=cfg2G rx-chains=0,1,2,3 security=\
    "Security config 2G" ssid="WiFi" tx-chains=0,1,2,3
add channel=channel5G channel.band=5ghz-onlyn country=sweden datapath=\
    datapath5G mode=ap name=cfg5G rx-chains=0,1,2,3 security=\
    "Security config 5G" ssid=WiFi2 tx-chains=0,1,2,3
add channel.band=5ghz-n/ac .control-channel-width=20mhz .extension-channel=\
    XXXX country=sweden datapath.client-to-client-forwarding=yes \
    .local-forwarding=yes name=cfg-5ghz-ac security="Security config 5G"
add channel.band=5ghz-onlyn .control-channel-width=20mhz .extension-channel=\
    .local-forwarding=yes name=cfg-5ghz-an security="Security config 5G"
/caps-man interface
add channel=channel5G configuration=cfg5G configuration.mode=ap datapath=\
    datapath5G disabled=no mac-address=00:00:00:00:00:00 master-interface=\
    none name=capsman radio-mac=00:00:00:00:00:00 radio-name="" security=\
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.11-192.168.88.254
add address-pool=dhcp interface=bridge lease-script="# DNS TTL to set for DNS \
    entries\
    \n:local dnsttl \"00:15:00\";\
    \n\
    \n###\
    \n# Script entry point\
    \n#\
    \n# Expected environment variables:\
    \n# leaseBound         1 = lease bound, 0 = lease removed\
    \n# leaseServerName    Name of DHCP server\
    \n# leaseActIP         IP address of DHCP client\
    \n#leaseActMAC      MAC address of DHCP client\
    \n###\
    \n\
    \n# \"a.b.c.d\" -> \"a-b-c-d\" for IP addresses used as replacement for mi\
    ssing host names\
    \n:local ip2Host do=\\\
    \n{\
    \n  :local outStr\
    \n  :for i from=0 to=([:len \$inStr] - 1) do=\\\
    \n  {\
    \n    :local tmp [:pick \$inStr \$i];\
    \n    :if (\$tmp =\".\") do=\\\
    \n    {\
    \n      :set tmp \"-\"\
    \n    }\
    \n    :set outStr (\$outStr . \$tmp)\
    \n  }\
    \n  :return \$outStr\
    \n}\
    \n\
    \n:local mapHostName do={\
    \n# param: name\
    \n# max length = 63\
    \n# allowed chars a-z,0-9,-\
    \n  :local allowedChars \"abcdefghijklmnopqrstuvwxyz0123456789-\";\
    \n  :local numChars [:len \$name];\
    \n  :if (\$numChars > 63) do={:set numChars 63};\
    \n  :local result \"\";\
    \n\
    \n  :for i from=0 to=(\$numChars - 1) do={\
    \n    :local char [:pick \$name \$i];\
    \n    :if ([:find \$allowedChars \$char] < 0) do={:set char \"-\"};\
    \n    :set result (\$result . \$char);\
    \n  }\
    \n  :return \$result;\
    \n}\
    \n\
    \n:local lowerCase do={\
    \n# param: entry\
    \n  :local lower \"abcdefghijklmnopqrstuvwxyz\";\
    \n  :local upper \"ABCDEFGHIJKLMNOPQRSTUVWXYZ\";\
    \n  :for i from=0 to=([:len \$entry] - 1) do={\
    \n    :local char [:pick \$entry \$i];\
    \n    :local pos [:find \$upper \$char];\
    \n    :if (\$pos > -1) do={:set char [:pick \$lower \$pos]};\
    \n  }\
    \n}\
    \n\
    \n:local token \"\$leaseServerName-\$leaseActMAC\";\
    \n:local LogPrefix \"DHCP2DNS (\$leaseServerName)\"\
    \n\
    \n:if ( [ :len \$leaseActIP ] <= 0 ) do=\\\
    \n{\
    \n  :log error \"\$LogPrefix: empty lease address\"\
    \n  :error \"empty lease address\"\
    \n}\
    \n\
    \n:if ( \$leaseBound = 1 ) do=\\\
    \n{\
    \n  # new DHCP lease added\
    \n  /ip dhcp-server\
    \n  #:local dnsttl [ get [ find name=\$leaseServerName ] lease-time ]\
    \n  network\
    \n  :local domain [ get [ find \$leaseActIP in address ] domain ]\
    \n  :log info \"\$LogPrefix: DNS domain is \$domain\"\
    \n\
    \n  :local hostname [/ip dhcp-server lease get [:pick [find mac-address=\$\
    leaseActMAC and server=\$leaseServerName] 0] value-name=host-name]\
    \n  #:log info \"\$LogPrefix: DHCP hostname is \$hostname\"\
    \n\
    \n #Hostname cleanup\
    \n  :if ( [ :len \$hostname ] <= 0 ) do=\\\
    \n  {\
    \n    :set hostname [ \$ip2Host inStr=\$leaseActIP ]\
    \n    :log info \"\$LogPrefix: Empty hostname for '\$leaseActIP', using ge\
    nerated host name '\$hostname'\"\
    \n  }\
    \n  :set hostname [\$lowerCase entry=\$hostname]\
    \n  :set hostname [\$mapHostName name=\$hostname]\
    \n  #:log info \"\$LogPrefix: Clean hostname for FQDN is \$hostname\";\
    \n\
    \n  :if ( [ :len \$domain ] <= 0 ) do=\\\
    \n  {\
    \n    :log warning \"\$LogPrefix: Empty domainname for '\$leaseActIP', can\
    not create static DNS name\"\
    \n    :error \"Empty domainname for '\$leaseActIP'\"\
    \n  }\
    \n\
    \n  :local fqdn (\$hostname . \".\" .  \$domain)\
    \n  #:log info \"\$LogPrefix: FQDN for DNS is \$fqdn\"\
    \n\
    \n    :if ([/ip dhcp-server lease get [:pick [find mac-address=\$leaseActM\
    AC and server=\$leaseServerName] 0] ]) do={\
    \n      # :log info message=\"\$LogPrefix: \$leaseActMAC -> \$hostname\"\
    \n      :do {\
    \n        /ip dns static add address=\$leaseActIP name=\$fqdn ttl=\$dnsttl\
    \_comment=\$token;\
    \n      } on-error={:log error message=\"\$LogPrefix: Failure during dns r\
    egistration of \$fqdn with \$leaseActIP\"}\
    \n    }\
    \n\
    \n} else={\
    \n# DHCP lease removed\
    \n  /ip dns static remove [find comment=\$token];\
    \n}\
    \n" lease-time=10m name=DhcpWithScript
/ip smb users
/port
set 0 name=serial0
/ppp profile
set *0 interface-list=LAN
set *FFFFFFFE interface-list=LAN
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/caps-man manager
set enabled=yes upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
    cfg2G
add action=create-dynamic-enabled hw-supported-modes=an,ac \
    master-configuration=cfg5G
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
    cfg-5ghz-ac name-format=prefix-identity name-prefix=5ghz-ac
add action=create-dynamic-enabled hw-supported-modes=an master-configuration=\
    cfg-5ghz-an name-format=prefix-identity name-prefix=5ghz-an
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
    internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10 \
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 \
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 \
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=wireguard list=LAN
/interface ovpn-server server
set auth=sha1 certificate=server cipher=aes256-cbc default-profile=\
    default-encryption enabled=yes port=9606 require-client-certificate=yes
/interface wireguard peers
add allowed-address=192.168.87.2/24 comment="ilja macbook" interface=\
    wireguard name=peer1 public-key=\
    "snMBiNdXULctRPfQFiXq7ylrOPzsOGY6y60QUcM/tkU="
add allowed-address=192.168.87.3/24 comment="ilja iPhone 12Pro" interface=\
    wireguard name=peer2 public-key=\
    "AgfQTMgy1PDoKewb4hOE8BtiD/3xZ5DoKXYTzfGuZg8="
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 discovery-interfaces=bridge \
    enabled=yes interfaces=wlan1
    192.168.88.0
add address=87.96.165.183/25 interface=ether1 network=87.96.165.128
add address=192.168.87.1/24 comment=wireguard interface=wireguard network=\
    192.168.87.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.21 comment="manually added" name=iphone-ll
/ip firewall address-list
add address=467304b1dbaf.sn.mynetname.net comment="IP-Cloud feature" list=\
    WAN-IP
    established,related,untracked
    invalid
    "Allow WireGuard VPN to enter local network" dst-port=33333 protocol=udp
add action=accept chain=input comment="Allow OpenVPN" dst-port=9606 \
    in-interface=ether1 protocol=tcp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=accept chain=forward comment="internet traffic" in-interface-list=\
    LAN out-interface-list=WAN
add action=accept chain=forward comment="WG to LAN" dst-address=\
    192.168.88.0/24 in-interface=wireguard
add action=accept chain=forward comment="port forwarding" \
    connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
    connection-state=invalid
add action=masquerade chain=srcnat comment="HAIRPIN NAT" dst-address=\
    192.168.88.0/24 src-address=192.168.88.0/24 to-addresses=192.168.88.10
add action=dst-nat chain=dstnat comment="Traefik HTTP" dst-address-list=\
    WAN-IP dst-address-type="" dst-port=80 in-interface=ether1 protocol=tcp \
    to-addresses=192.168.88.5 to-ports=9080
add action=dst-nat chain=dstnat comment="Traefik HTTPS" dst-address-list=\
    WAN-IP dst-address-type=local dst-port=443 in-interface=ether1 protocol=\
    tcp to-addresses=192.168.88.5 to-ports=9443
add action=dst-nat chain=dstnat comment="Hairpin - Traefik HTTP" \
    dst-address-list=WAN-IP dst-address-type=local dst-port=80 protocol=tcp \
add action=dst-nat chain=dstnat comment="Hairpin - Traefik HTTPS" \
    dst-address-list=WAN-IP dst-address-type=local dst-port=443 protocol=tcp \
/ip service
set www port=82
set www-ssl certificate=server port=4443
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set always-allow-password-login=yes
/lcd interface pages
set 0 interfaces=wlan1
/ppp secret
add comment="Ilja's OpenVPN" local-address=192.168.88.1 name=leikoilja \
    profile=default-encryption remote-address=192.168.88.151 service=ovpn
add comment="Jess OpenVPN" local-address=192.168.88.1 name=jess profile=\
    default-encryption remote-address=192.168.88.152 service=ovpn
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Stockholm
/system identity
set name="MikroTik Hub"
/system note
set show-at-login=no
/system routerboard settings
# Firmware upgraded successfully, please reboot for changes to take effect!
# Warning: cpu not running at default frequency
set auto-upgrade=yes cpu-frequency=700MHz silent-boot=yes
/system script
add comment=\
    "from https://www.ctrl.blog/entry/routeros-dhcp-lease-script.html" \
    dont-require-permissions=no name="DHCP to DNS" owner=leikoilja policy=\
    ftp,read,write,policy,test,password,sniff,sensitive,romon source="# DNS TT\
    L to set for DNS entries\
    \n\
    \n###\
    \n#\
    \n###\
    \n\
    \n:local leaseServerName \"DhcpWithScript\"\
    \n\
    \n\
    ssing host names\
    \n{\
    \n  :local outStr\
    \n  {\
    \n    {\
    \n      :set tmp \"-\"\
    \n    }\
    \n  }\
    \n}\
    \n\
    \n# param: name\
    \n\
    \n  }\
    \n}\
    \n\
    \n# param: entry\
    \n  }\
    \n}\
    \n\
    \n\
    \n{\
    \n}\
    \n\
    \n{\
    \n  /ip dhcp-server\
    \n  network\
    \n  #:log info \"\$LogPrefix: DNS domain is \$domain\"\
    \n\
    \n\
    \n  {\
    \n  }\
    \n\
    \n  {\
    \n  }\
    \n\
    \n\
    \n      :do {\
    \_comment=\$token;\
    \n    }\
    \n\
    \n} else={\
    \n}\
    \n\
    \n"
/tool mac-server
/tool mac-server mac-winbox
/user group
add name=homeassistant policy="read,test,api,!local,!telnet,!ssh,!ftp,!reboot,\
    !write,!policy,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api"
However, sadly still no WAN access from iphone using wireguard :frowning:
Attached is the wireguard tunnel settings on iphone
add action=accept chain=forward comment=“WG to LAN” dst-address=
But your WG-client has 192.168.87.x config ?
hm, i thought i should interpret it as traffic coming from wireguard interface should be forwarded to destination addressed (192.168.88.0/24) which is my LAN.
but at this point i m just ready to try anything :smiley: tried changing it to 192.168.87.0/24 - unfortunately no difference at all:
i can still reach my router on 192.168.88.1 but no external WAN access :open_mouth:
My mistake. You are right on this one.****
But please make sure you enable LOGGING LOGGING LOGGING on all your rules so perhaps you have any idea where your packets are “stuck”
Well this rule is not going to help you get to the internet!
You are allowing to pass ONLY for traffic towards 192.168.88.x
If you punch www.facebook.com on your mobile device obviously you need to be allowed to pass the forward chain on your way to Facebook etc. This is not the case with the above rule!
Are you not getting any LOGS in the DROP in the FORWARD chain ? Activate LOG and see what & where it happens.
I have a rule more “generic” that allow my Wireguard “range” as a whole, without “dst-ip” in there.
Thanks, @jvanhambelgium, for your help.
So i have relaxed my Wireguard rule to be this now:
14    ;;; WG to LAN
      chain=forward action=accept in-interface=wireguard out-interface-list=LAN log=no log-prefix=""
16    ;;; drop all else
      chain=forward action=drop log=yes log-prefix="firewall"
no progress yet.
also tried enabling logs (especially on the DROP forward chain as you suggested) and here are the only records i could see related to my current peer’s endpoint address 94.234.96.**:
20:40:51 firewall,info firewall input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:a1:9b, proto UDP, 94.234.96.**:49725->213.112.***.**:33333, len 60
20:40:51 firewall,info firewall input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:a1:9b, proto UDP, 94.234.96.**:49725->213.112.***.**:33333, len 176
20:41:21 firewall,info firewall input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 94.234.96.**:49725->213.112.***.**:33333, len 60
20:41:27 firewall,info firewall input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 94.234.96.**:49725->213.112.***.**:33333, len 60
20:41:36 firewall,info firewall input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 94.234.96.**:49725->213.112.***.**:33333, len 60
20:41:36 firewall,info firewall input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 94.234.96.**:49725->213.112.***.**:33333, len 124
Edit: also noticed now that my rule 8 is doing smth shady with a lot of traffic coming from the mac address that i can track to my connected iphone over wireguard:
 8    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN log=yes log-prefix="rule 8"
21:00:03 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto TCP (SYN), 194.180.49.**:41262->213.112.***.**:62311, len 40
21:00:15 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto TCP (SYN), 91.191.209.***:42959->213.112.***.**:3777, len 40
21:00:17 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 223.113.128.***:58324->213.112.***.**:520, len 52
21:00:41 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto TCP (SYN), 167.94.138.***:61304->213.112.***.**:4567, len 60
21:00:43 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto TCP (SYN), 159.223.73.***:6116->213.112.***.**:22, len 44
21:00:54 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 31.13.72.*:443->213.112.***.**:54062, len 76
21:00:54 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 31.13.72.*:443->213.112.***.**:54062, len 61
21:00:55 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 31.13.72.*:443->213.112.***.**:54062, len 61
21:00:57 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 31.13.72.*:443->213.112.***.**:54062, len 61
21:00:59 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 31.13.72.*:443->213.112.***.**:54062, len 61
21:01:05 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto UDP, 31.13.72.*:443->213.112.***.**:54062, len 61
21:01:10 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto TCP (SYN), 88.80.20.**:55366->213.112.***.**:7314, len 40
21:01:12 firewall,info rule 8 input: in:ether1 out:(unknown 0), connection-state:new src-mac ee:13:db:7e:**:**, proto TCP (SYN), 71.6.232.**:46100->213.112.***.**:8443, len 44
but i have no idea what to do with that now :confused:
The thing is, you need SOME rule that get hit with packets having source-IP = 192.168.87.3 (eg. you phone) and wanting to go out on the Internet (once it arrives from the wireguard decapsulation/decrypt)
So perhaps DO enable some logging on FORWARD rules to, even the ALLOWED ones regarding Wireguard.
It is really the first step in making your problem visible something so you can act. Something rules needs to be moved around because it is too low in the chain etc)
If your router is not doing TOO much traffic, logging-output will not be crazy.
For the record in your app on your phone you DO see the Tx & Rx counters increase ?? Or does 1 of them remain at “0” ? What about “last handshake” in the wireguard-menu → peers ?
Okay this is quite unexpected, but it HAS WORKED NOW!
So i have enabled logs for ALL the firewall filter rules i have, and piped my logs from terminal to only see expected 192.168.87.3:
log print follow where message~“192.168.87.”
when i visit 192.168.88.1 which is my router - i get the page and see bunch of logs running from firewall, the packets RX/TX also increase on phone’s wireguard client.
but if i visit anything like google.com / facebook.com etc.. nothing changes… no RX/TX packets changes, no logs printed… dead silent.
then i went into iphone’s wireguard tunnel settings and they have a field for DNS servers and the comment strongly recommended, so in the spirit of try-and-error i put in google DNS 8.8.8.8 and BOOM - everything just smoooothly works as "expected’ :open_mouth: :open_mouth: :open_mouth:
i guess my DNS servers on the router are messed up (from the times i was playing with pihole and AdGuard home)…
will try to find a place to set default DNS servers on the router and get rid of setting those on iphone wireguard client, but at least things are finally working now, WOHO!!
Big big thank you @jvanhambelgium and @anav for all the help! :sunglasses: :raised_hands:
As I suspected DNS was an issue.
Also on my wireguard iphone settings, the wireguard IP address is put as /32 NOT /24.
Ahh…you did not even have a DNS server configured then for you Wireguard connection !!!
Yeah … that explains a lot…
Anyway, glad it works now.
You can disabled some logging now :wink:
