Hello everyone.
I recently decided to give my home network a somewhat radical restyling. Thus, being the configuration I previously had on my faithful RB3011UiAS-r2 totally incompatible with the new setup, I decided to reset the box, update it to the last ROS version, and to start over from scratch.
Unfortunately, I’m currently stuck in a problem I apparently and embarassingly can’t solve by myself, so I’m here begging for your wise help trying to find a viable solution.
OVERALL SETUP DESCRIPTION: The 3011 sits at the core of my network and, for what’s relevant for the current problem, it’s connected to:
- “WAN1/2/3/4”: 4 x different WAN providers for redundancy, of which just the first one is connected until I solve the current issue (part of “WANX” list);
- “SRVR”: the server’s VLAN, the only one allowed to connect to the outer world (part of “LANX” list);
- Many other VLANs, not allowed to connect to the other world via the related fw rules I’m going to add once the current issue will be solved.
Every port of the 3011 - except the emergency management one - is connected to VLAN-aware devices and tagged/filtered as such.
PROBLEM DESCRIPTION: The 3011 connects to the Internet on PPPoE without any problem and everything works well from its terminal (e.g. ping, DNS resolution, firmware updates, NTP, etc.). The “LANX” bridged VLANS have no problem at all in communicating the one with the other and with the 3011, from which they can regularly receive DNS replies. The only problem is that the “LANX” VLANs (that is, the “SRVR” VLAN) can’t exit the router using its “WANX” interface (no ping, and tracert dies at the gates of the gateway).
WHAT I TRIED TO DO: I temporarily disabled the rules on the fw, and tried to modify in many ways the masquerade rule parameters, but nothing changed.
(The following config has been intentionally censored in many sections, however objectively irrelevant for the current topic.)
RouterOS Version: 7.x (last update)
add name=LANX vlan-filtering=yes
add name=WANX vlan-filtering=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
[CENSORED]
add interface=LANX name=SRVR vlan-id=10
add interface=WANX name=WAN1 vlan-id=70
add interface=WANX name=WAN2 vlan-id=60
add interface=WANX name=WAN3 vlan-id=50
add interface=WANX name=WAN4 vlan-id=40
/interface pppoe-client
add add-default-route=yes disabled=no interface=WAN1 name=pppoe-out1 service-name=[CENSORED] use-peer-dns=yes user=[CENSORED]
add name=WAN
add name=LAN
add name=OTHER
set [ find default=yes ] supplicant-identity=[CENSORED]
[CENSORED]
[CENSORED]
/port
set 0 name=serial0
add bridge=WANX frame-types=admit-only-vlan-tagged interface=ether1 pvid=70
add bridge=WANX frame-types=admit-only-vlan-tagged interface=ether2 pvid=60
add bridge=WANX frame-types=admit-only-vlan-tagged interface=ether3 pvid=50
add bridge=WANX frame-types=admit-only-vlan-tagged interface=ether4 pvid=40
[CENSORED]
add bridge=LANX frame-types=admit-only-vlan-tagged interface=ether8 pvid=10
[CENSORED]
set discover-interface-list=[CENSORED]
/interface bridge vlan
add bridge=WANX tagged=WANX,ether1 vlan-ids=70
add bridge=WANX tagged=WANX,ether2 vlan-ids=60
add bridge=WANX tagged=WANX,ether3 vlan-ids=50
add bridge=WANX tagged=WANX,ether4 vlan-ids=40
[CENSORED]
add bridge=LANX tagged=LANX,ether8 vlan-ids=10
[CENSORED]
add interface=WANX list=WAN
add interface=SRVR list=LAN
[CENSORED]
add address=192.168.50.1/30 interface=WAN2 network=192.168.50.0
add address=192.168.100.1/30 interface=WAN3 network=192.168.100.0
add address=192.168.150.1/29 interface=WAN4 network=192.168.150.0
[CENSORED]
[CENSORED]
[CENSORED]
add address=10.128.64.254/24 interface=SRVR network=10.128.64.0
/ip cloud
set update-time=no
/ip dhcp-server lease
[CENSORED]
[CENSORED]
set allow-remote-requests=yes servers=8.8.8.8
add action=drop chain=input connection-state=invalid
add action=accept chain=input connection-state=established,related
add action=drop chain=input in-interface-list=WAN
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes
add action=accept chain=forward connection-state=new connection-type="" in-interface-list=LAN
add action=accept chain=forward connection-state=established,related
add action=drop chain=forward connection-nat-state=!dstnat connection-state=""
/ip service
[CENSORED]
/ip ssh
[CENSORED]
/lcd
set default-screen=stat-slideshow
/lcd pin
set pin-number=[CENSORED]
/lcd interface
set ether1 disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set sfp1 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
set ether10 disabled=yes
add interface=WAN1 max-speed=auto
add interface=WAN2 max-speed=auto
add interface=WAN3 max-speed=auto
add interface=WAN4 max-speed=auto
[CENSORED]
add interface=SRVR max-speed=auto
[CENSORED]
/system clock
set time-zone-name=[CENSORED]
/system identity
set name=[CENSORED]
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=[CENSORED]
/tool mac-server mac-winbox
Thank you in anticipation for any help.
