Can you install only wireless package from http://www.mikrotik.com/download ?
Download from MIPSBE - Extra Packages the file for 6.37.2 and extract it.
Then open winbox, go to Files and drag ‘n’ drop the Wireless package in files.
Then do a reboot.
Here is a note from 6.37 changelog:
“If you are not using “routeros” bundle package and have two wireless packages installed, uninstall one wireless package before upgrade to 6.37. For other cases simply upgrade to 6.37 version.”
It means that if you have older RouterOS than 6.37 and have multiple separate wireless packages (for example, wireless-fp and wireless-cm2) installed, then you have to remove one of them and upgrade only afterwards.
I have uploaded
wireless-6.37.2-mipsbe.npk
and reboot the router.
After rebooting wlan1 interface appeared and it was disabled.
I have enabled it and its cofig is following:
I can also scan other networks:
[admin@MikroTik] /interface wireless> scan
number: 0
Flags: A - active, P - privacy, R - routeros-network,
N - nstreme, T - tdma, W - wds, B - bridge
ADDRESS SSID CHANNEL SIG NF SNR RA
AP 00:24:FE:xx:xx:xx MONIKA 2412/… -87 -103 16
AP 90:F6:52:xx:xx:xx Villa Bl… 2412/… -90 -103 13
AP A0:EC:80:xx:xx:xx ilija 2412/… -81 -103 22
A 00:02:6F:xx:xx:xx AirDSL 2422/… -87 -105 18
AP 60:E3:27:xx:xx:xx ICS sistemi 2462/… -72 -105 33
AP 40:B8:9A:xx:xx:xx HP-Print… 2462/… -72 -105 33
A 00:02:6F:xx:xx:xx SunWirel… 2462/… -84 -105 21
AP 54:22:F8:xx:xx:xx Villa Bl… 2437/… -92 -104 12
P 8C:E0:81:xx:xx:xx APARTMAN… 2437/… -90 -104 14
the problem now is that led indicator for wifi is off and i can not see SSID
