Hi!
I can not connect to my router over WinBox (all other Mikrotik devices work fine).
I can not connect via MAC address.
I can access the router over serial and WebFig.
I can ping it from another Mikrotik device and my PC.
I can connect over RoMON.
My PC is connected on ether3.
Any ideas?
# 2024-11-29 01:55:28 by RouterOS 7.16.2
# software id = XXX
# model = RB2011UiAS-2HnD
# serial number = XXX
add admin-mac=64:D1:54:80:E4:98 auto-mac=no name=main-bridge port-cost-mode=short
/interface wireless
# managed by CAPsMAN
# channel: 2447/20-eC/gn(26dBm), SSID: lord-of-the-ping, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-80E4A1 wireless-protocol=802.11
set [ find default-name=ether1 ] comment="PoE IN" name="ether1[lag9]"
set [ find default-name=ether2 ] name="ether2[lag10]"
set [ find default-name=ether6 ]
set [ find default-name=ether7 ]
set [ find default-name=ether8 ]
set [ find default-name=ether9 ]
set [ find default-name=ether10 ]
/interface bonding
add comment="Bonding dg 1,2 === core-switch 6,8" mode=802.3ad name=bonding-core-router slaves="ether1[lag9],ether2[lag10]"
/port
set 0 name=serial0
add bridge=main-bridge interface=ether3
add bridge=main-bridge interface=ether4
add bridge=main-bridge interface=ether5
add bridge=main-bridge interface=ether6
add bridge=main-bridge interface=ether7
add bridge=main-bridge interface=ether8
add bridge=main-bridge interface=ether9
add bridge=main-bridge interface=ether10
add bridge=main-bridge interface=sfp1
add bridge=main-bridge interface=bonding-core-router
add bridge=main-bridge interface=wlan1
add bridge=main-bridge interface=*14
set udp-timeout=10s
set discover-interface-list=*2000011
/ipv6 settings
set disable-ipv6=yes forward=no
/interface wireless cap
set certificate=request discovery-interfaces="ether1[lag9]" enabled=yes interfaces=wlan1
/ip dhcp-client
add interface=main-bridge
set allow-remote-requests=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=*2000010
/ip ipsec profile
/ip service
set ftp disabled=yes
set winbox address=10.10.0.0/16
/snmp
set contact="aaron" enabled=yes location=DG
/system clock
/system identity
set name=dg-router
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool mac-server ping
set enabled=no
/tool romon
set enabled=yes
/tool romon port
add disabled=no forbid=yes interface=wlan1
