No Winbox connection to AP (RBwAP2nDr2)
Hello folks,
I have problem to connect from PC to AP (eth1). AP is reseted to factory defaults. Winbox see the AP but when I triyng to connect it shows me ERROR: could not connect to MAC-ADDRESS-OF-AP
The only way how to connect to this AP is turn on the AP. Connect via wirelless device to this AP via wifi network which is defaultly created on this AP. Then connect from Winbox via MAC address.
The neighbor discovery is enabled on Eth1. The default firewall rules are deleted from the AP. NAT rule is also deleted from the AP but I still unable to connect directly via cable to Eher1. I have the newest firmware and also RouterOS package on this AP. Also Im using the newest Winbox which is 3.7.
Does anybody facing similar problem?
Thanks for any advice.
Go into an AP by wireless, reset to factory settings (no default configuration) and then try again by cable.
