hello! Hope you all are doing well! I am currently running a PA-820 as my router and a CRS326 as my switch, and my two AP’s are cAP AC’s . The problem is the WIFI / wireless networking does not seem to work at all. It connects but says no internet and gives the error DNS probe possible most of the time. But all of the other devices over ethernet work perfect!
I hope you all can help me troubleshoot this.
let me know what kind of info you may need to help me out here!
Thanks!
mkx
November 30, 2022, 7:31pm
2
Start off by posting full configuration of one of your cAP acs. Execute /export hide-sensitive file=anynameyouwish in terminal window, fetch resulting file from device, open it with text editor, redact any remaining sensitive information (e.g. serial number, any usernames or passwords) and copy-paste it inside [__code] [/code] block.
# jan/04/1970 20:56:18 by RouterOS 7.6
# software id = V72X-Q95Z
# model = RBcAPGi-5acD2nD
# serial number = REDACTED
add admin-mac=18:FD:74:5E:75:95 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country="united states3" disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid="The Wave Admin" \
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add name=profile supplicant-identity=MikroTik
/interface wireless
add disabled=no mac-address=1A:FD:74:5E:75:97 master-interface=wlan2 name=\
wlan3 security-profile=profile ssid="The Wave Visitor"
add disabled=no mac-address=1A:FD:74:5E:75:96 master-interface=wlan1 name=\
wlan4 security-profile=profile ssid="The Wave Visitor"
/ip hotspot profile
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
/interface bridge filter
add action=drop chain=forward in-interface=wlan3
add action=drop chain=forward out-interface=wlan3
add action=drop chain=forward in-interface=wlan4
add action=drop chain=forward out-interface=wlan4
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=wlan4
/interface wireless access-list
add ap-tx-limit=16 interface=wlan4
add ap-tx-limit=16 interface=wlan3
add address=192.168.88.3/24 comment=defconf interface=bridge network=\
192.168.88.0
add address=192.168.88.3/24 interface=ether1 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
192.168.88.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.3 comment=defconf name=router.lan
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
mkx
November 30, 2022, 8:28pm
4
The cAP ac is configured as router with ether1 as WAN interface. If you want to make cAP ac a simple AP, which will make clients normal members of the rest of LAN, then you have to reconfigure device. I’m not sure if QuickSet offers appropriate mode (manual page doesn’t show one), so you’ll have to do it manually.
The basic idea is the following: reset device to empty config (no default config). After that connect using winbox, create bridge, add all interfaces to bridge (both ether ports and both wireless ports), add DHCP client on bridge. Then set up wireless parameters.
If you want to add guest wireless, you’ll have to configure a few other things (a separate subnet with DHCP server, firewall protecting the rest of LAN, etc)
Your current config shows guest wlan setup, but clients can not possibly use it. Bridge filter rules block any teaffic between guest wlan interfaces and the rest of network (so only communication with cAP ac is possible), but DHCP server is disabled. Also setup is trying to use both WAN interface (ether1) and bridge with same IP address / subnet which makes lots of confusion when it tries to route packets between both sides.
I don’t know what the router is… But I don’t think it’s a Tik.
Put caps-man config on the switch. Make it the manager. Set local forwarding and client to client forwarding.
Now that I looked it up…
I still say… Make the switch the caps-manager. Then default both Caps and set them to caps-mode.
