No Wlan interface Showing up
Well here is the newest problem!
I have a RB433AH that is not showing any wireless cards installed!!
I have tried many radio R52, R52H, R5H, and Xr2 all with the same results. Each radio has be placed into another RB and work fine.
It does not matter what slot I place the radio into, However if I have a radio installed I am able to see it in the /system resource PCI
[admin@MikroTik] > /system resource pci print
DEVICE VENDOR NAME IRQ
0 00:12.0 Atheros Communications, Inc. AR5006X 802.11abg NIC (... 48
Here is the boot up while connected to the console
RouterBOOT booter 2.27
RouterBoard 433AH
CPU frequency: 680 MHz
Memory size: 128 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
Oops[#1]:
Cpu 0
$ 0 : 00000000 1000c600 d0020000 deadc0de
$ 4 : c6c38000 c6c386f4 c6c386f6 d000e02c
$ 8 : 00000000 00011000 fffe0000 c7a8d800
$12 : dffc4000 00000002 00000000 00000000
$16 : c6c38000 c6c38000 c7816800 c6c3a7a8
$20 : d0020000 10000000 c6cf0000 004398e0
$24 : c6c41ac8 00000000
$28 : c6c40000 c6c41cd8 00437e60 c6d012b4
Hi : 00000000
Lo : 00000000
epc : c6d09df8 a5212_hw_readver+0x1c/0x34 [a5212]
Tainted: P
ra : c6d012b4 a5212_init+0x24/0xc74 [a5212]
Status: 1000c603 KERNEL EXL IE
Cause : 1080001c
PrId : 00019374 (MIPS 24K)
Process insmod (pid: 861, threadinfo=c6c40000, task=c79048b0, tls=00000000)
Stack : d0030000 c037bd00 0ffe0000 3ffe0000 000005df 00000000 c6ced214 c6c38000
c7816800 c6ced214 c034be30 10000000 c6c3a7a8 c6c38000 c7816800 c6cec2a0
10000000 00002728 c0390000 00000002 c7850960 c7498260 c6ced214 c6ced1e0
c7816800 c6ced214 c034be30 00000000 00438290 c0216678 c7812750 00000000
00000000 00000001 c7816858 c7816858 c6ced214 c0235f04 c78113c8 c01d33d4
Call Trace:
[] a5212_hw_readver+0x1c/0x34 [a5212]
[] a5212_init+0x24/0xc74 [a5212]
[] 0xc6cec2a0
Code: 00000000 8c8206c8 8c434020 <306200ff> 00021102 3063000f a4a20000 03e0 0008 a4c30000
---[ end trace 9a2c626d991c0337 ]---
rb400-spi rb400-spi: uevent: unsupported action-string; this will be ignored in a future kernel version
platform ag7100: uevent: unsupported action-string; this will be ignored in a future kernel version
Netfilter messages via NETLINK v0.30.
ctnetlink v0.93: registering with nfnetlink.
ip6_tables: (C) 2000-2006 Netfilter Core Team
ip_tables: (C) 2000-2006 Netfilter Core Team
netfilter PSD loaded - (c) astaro AG
reset ag7100
eth0: reset unit 1 (phy 4)
switch0: reset unit 0 (phy 175)
icplus175c_setup
rb400-led rb400-led: uevent: unsupported action-string; this will be ignored in a future kernel version
serial8250 serial8250: uevent: unsupported action-string; this will be ignored in a future kernel version
rb400-spi-misc spi0.0: uevent: unsupported action-string; this will be ignored in a future kernel version
rb400-spi-nand spi0.1: uevent: unsupported action-string; this will be ignored in a future kernel version
spi spi0.2: uevent: unsupported action-string; this will be ignored in a future kernel version
mmc_spi spi0.2: ASSUMING 3.2-3.4 V slot power
mmc_spi spi0.2: SD/MMC host mmc0, no DMA, no WP, no poweroff
eth0: open
eth0: reset phy 0
switch0: open
icplus175c_setup
eth1: reset phy 0
eth0: reset phy 0
eth1: reset phy 0
switch0: stop
switch0: open
icplus175c_setup
eth1: reset phy 0
eth0: reset phy 0
eth1: reset phy 0
eth2: reset phy 0
rb400_beep 5000
rb400_beep 0
eth2: reset phy 0
rb400_beep 5000
rb400_beep 0
rb400_beep 0
mmc0: error -22 whilst initialising SDIO card
eth0: phy speed: 100, fdx: 1
MikroTik 4.11
MikroTik Login:
[admin@MikroTik] /system routerboard> print
routerboard: yes
model: "433AH"
serial-number: "1A7701DA860B"
current-firmware: "2.27"
upgrade-firmware: "2.27"
Any HELP would be GREAT!!! I have reloaded 4.11 Many TIMES I have Loaded 3.30 I have upgraded the firmware to 2.27 NOTHNING WORKS!!
try to change power supply… and upgrade sofrware..
