No work v6 v7 (Local Network Queue and Internet Traffic)
How to split speed client access to the global network and local resources provider:
http://asp24.com.ua/blog/mikrotik-queue-internet-otdelno-lokalnye-resursy-otdelno-video/
http://asp24.com.ua/blog/kak-razdelit-skorost-dostupa-klienta-v-globalnuyu-set-i-k-lokalnym-resursam-provajdera/
It works on version 5 why does not work on version 6 :angry:
I need to divide the network speed from 0 to 100 Mbps and a separate share of internet traffic from 0 to 5 Mbit
Internet to 5Mbit (0.0.0.0/0)
Local resources to 100Mbps (10.0.0.0/8; 172.0.0.0/21)
Mikrotik RB751U
I am also in that problem any body help us
Not advanced menu v6.13: P2P, Dst.Address, Interface
You work on the problem?
The video and the text on links are on Russian language, and this is an English language forum.
No one of us (users, not MikroTik members) work at any problem.
Contact MikroTik directly.
Have you read the notice at the beginning of the forum?
Notice: For support from Mikrotik staff, write to support@mikrotik.com - Mikrotik does not generally offer support on the forum, this is a user forum
On the version 6.x traffic flow, simple and queue tree are changed.
Revert to 5.26 and frequent one MikroTik course, for understand how the thing works, in this way everytime something change, you understand how fix it,
instead to just “copy & paste” from the guide you find over internet, and on the first change go to panic.
You bad work :confused:
I did it myself :slight_smile:
Molodec !
