I’m trying to replace our HomeHub with an RB951G, but can’t quite get it to work.
Has anyone a step-by-step config guide for this setup, please?
After several resets and trying to do just what the manual for the initial config says http://wiki.mikrotik.com/wiki/Manual:Initial_Configuration#Summary
..I just let it do it all itself, not adding static DNS entries or anything else.
It dials-in and connects, gets an IP from the ISP, sets up DNS server references and acts as a local DHCP server - all good.
I can ping from the router, plus it will successfully check for updates, so it can see, and get responses from, the internet.
A pc, connected to the router can get an ip (via lan or wireless).
It can do DNS lookups, but cannot ping through.
I suspect either a firewall issue (I have left the default settings in place) or maybe need to add some sort of bridge between the pppoe interface and the rest of the interfaces, but not sure how to proceed.
Any advice gratefully taken!
Cheers - Simon
