noise floor
I have an RB532 with R52 miniPCI onboard configured as AP-BRIGE.
the ap interface is into a bridge with the other 3 ethernet port of the RB532.
When I connect the the antenna omni to the miniPCI the noise floor showed in the status windows on winbox is between -70 dbm and -78 db.
When I disconnect the antenna the noise floor goes to the expected values -99 dbm.
I have tried:
  • substituite the miniPCI, results are the same.
  • I have sobstituite the antenna and cables, results are the same
  • I have changed the antenna with a 2 db omni antenna, results show a -99 of noise floor, but power is very low, so clients cannot connect.
  • I have changed antenna mode from antenna A to antenna B, and connected the antenna to connector B also and the issue is showed to antenna B.
I have others 4 Access point with RB112 and RB532 configured like this one described above and the noise floor is around -98 dbm.
What could be the issue?
On the manual I have not found nothing about this parameter.
From my knowedge the SNR is calculate signal form the client - noise floor of the board.
If noise floor of the board is -90 and a client connected to the AP send a signal that after attenuation arrive to -70, the SNR (or signal strength) is 20dbm. but is noise floor is -70 the SNR is 0 db, = no communication.
BR
Max
Have you changed channels to see if the noise is another active AP on the same channel you are using?
Yes, at the end the channel 3 and 7 are the only with -99 of noise floor :frowning: .
I will check with the spectrum ana.
The MT does not view frequency activity
Also I have to add some info.
the SR52 must be set to b-only to work fine at channel 3 and 7.
in this AP I have 3 clients connected, when they will be connected.
:cry:
