Noise floor
Hi all
When I login in my RB112 AP I see the noise floor=60-70 in the status, is it too high? I noticed that in more than one tower.
Please help
Yes that would be very high, you would need rx signals in the -50 or better range to get a quality connection. some links will work with a lower signal but your though put may be compromised by the other traffic if it is 802.11b/g based. Other type or radio may make this spectrum useless. I would not be deploying in that environment, choose a different band or channel or change out your antenna if it is an omni.
Erik
