after upgrade 493ah to v4.1 nokia n95 , n86 dosnt browsing
Answer all these questions please.
about the problem:
- what appears in the mobile browser ?
- do computers browse fine ?
about the config:
- do you use proxy?
- do you use hotspot?
thanks normis
white page appares on mobile explorer.
browsing on pc is very fine.
i dont use proxy but i use hotspot.
note that hotspot enables proxy and settings that are set up there are used as proxy settings that is used by hotspot. set to cache on disk=no and max-chache-size=none
