Nomadix + Mesh Max + Mikrotik + WDS
I have the following setup:
Draytek Vigor 2820 → Nomadix AG3100 → Proxim Wireless Mesh Max 5054 → Routerboard 433AH
The vigor has the adsl line and gives internet feed to the nomadix.
The nomadix does the AAA authentication and there is also a radius server in Windows 2003.
The Mesh Max has a 2.4GHz Omni for clients and a 5GHz Panel for point-to-point connection with 433AH.
The 433AH also has a 2.4GHz Omni for clients and a 5GHz Panel for point-to-point connection with Mesh Max.
When i use “Access Point” mode on Mesh Max and “station pseudobridge” or “station pseudobridge clone” at 433AH and then bridge the 2.4GHz and 5GHz interfaces, only one client is able to get IP Address from Nomadix and connects to the internet.
When i use “Access Point WDS” mode on Mesh Max and “ap-bridge” at 433AH at 5GHz interface with static wds and rstp bridge enabled everything is fine.
So, my question is why it is only working with WDS?
Thank you,
Tasos
(sorry for my english)
Anyone?
