Non-Overlapping Channels?
Hey All,
I could use a little bit of help configuring some access points. I am in the US and am looking for some help finding the proper settings for my wireless frequencies to have non-overlapping channels.
Can anyone suggest configs for the following
802.11b/g/n 20Mhz
802.11b/g/n 20/40Mhz
802.11a/ac/n 20 Mhz
802.11a/ac/n 20/40Mhz
802.11a/ac/n 20/40/80Mhz
I think most of my confusion is coming from the Ce vs eC… Any help?
-Eric
Google is your friend - https://en.wikipedia.org/wiki/List_of_WLAN_channels :smiley:
Ce or Ceee mean centre channel plus next channel (or channels).
So 2412 Ce would be 2412 + 2432 - note on 2.4GHz we recommedn only 1 (2412), 6 (2437) & 11 (2462) with 20Mhz Channel widths to avoid overlapping coverage in busy sites with more than 1 AP.
Some devices also do not play well on 40Mhz so if you are running a public site try and disable extension channels.
On 5GHz AC 5210 Ceee uses 5170-5250 MHz, 5290MHz Ceee uses 5250-5330 so you can see adjacent chnnels do overlap just a little.
Setting your Wireless to the correct Country should show in bold the available channels for you on RouterOS, using Regulatory Domain will also ensure you keep your power and frequencies legal too.
Hope this helps
