Sir or Madame … Madame or Sir,
I’m brand new to Mikrotik and detailed router/firewall configuration. I recently received 5 static IPs from my Internet provider and I’d like to implement WAN port to service provider, a DMZ, a BitCoin mining subnet, an unassigned subnet and a subnet that services my wireless home infrastructure (An ASUS RT-N66U). To accomplish this task I’ve procured a RB750GL and am in the midst fo setting up the RouterOS to service my various networking / firewalling desires. However, I seem to be stuck in a place where things aren’t working. The IPs assigned to my interfaces are ether1 :: 75.<REAL_IP>.<REAL_IP>.[129-133] with DG of .128, ether2 :: 192.168.119.0/24, ether3 :: 192.168.120.0/24, ether4 :: 192.168.121.0/24 and , ether5 :: 192.168.122.0/24. I’ve verified DHCP is working as expected on ether[2-5] and that on each of those interfaces I can set an IP on an attached resource and see the router AS WELL AS let DHCP assign an IP and see the router. I have verified my staic IPs work and that the DG is truly / accurately For reference the logical layout of my infrastructure is ::
ComCast SMC cable router → RB750GL with 5 static IPs on ether1 and RFC1918 addys on ether[2-5] → RFC1918 assigned devices
The specifics of my RB750GL are RouterOS 5.20 Firmware 3.0 and my configuration backup export is →
# jan/02/1970 01:58:49 by RouterOS 5.20
# software id = EZEF-GBRZ
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"WAN / internet Interface" disabled=no full-duplex=yes l2mtu=1598 \
mac-address=D4:CA:6D:75:BA:9A master-port=none mtu=1500 name=ether1 \
speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"Web services interface" disabled=no full-duplex=yes l2mtu=1598 \
mac-address=D4:CA:6D:75:BA:9B master-port=none mtu=1500 name=ether2 \
speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"BTC mining activity interface" disabled=no full-duplex=yes l2mtu=1598 \
mac-address=D4:CA:6D:75:BA:9C master-port=none mtu=1500 name=ether3 \
speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"Unassigned activities interface." disabled=no full-duplex=yes l2mtu=1598 \
mac-address=D4:CA:6D:75:BA:9D master-port=none mtu=1500 name=ether4 \
speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"Home network interface" disabled=no full-duplex=yes l2mtu=1598 \
mac-address=D4:CA:6D:75:BA:9E master-port=none mtu=1500 name=ether5 \
speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=192.168.119.50-192.168.119.254
add name=dhcp_pool2 ranges=192.168.120.50-192.168.120.254
add name=dhcp_pool3 ranges=192.168.121.50-192.168.121.254
add name=dhcp_pool4 ranges=192.168.122.50-192.168.122.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=\
static disabled=no interface=ether2 lease-time=7w1d name=dhcp1
add address-pool=dhcp_pool2 authoritative=after-2sec-delay bootp-support=\
static disabled=no interface=ether3 lease-time=7w1d name=dhcp2
add address-pool=dhcp_pool3 authoritative=after-2sec-delay bootp-support=\
static disabled=no interface=ether4 lease-time=7w1d name=dhcp3
add address-pool=dhcp_pool4 authoritative=after-2sec-delay bootp-support=\
static disabled=no interface=ether5 lease-time=7w1d name=dhcp4
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=\
default use-encryption=default use-mpls=default use-vj-compression=\
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
use-compression=default use-encryption=yes use-mpls=default \
use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=\
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
winbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
no
set 0 vlan-header=leave-as-is vlan-mode=disabled
set 1 vlan-header=leave-as-is vlan-mode=disabled
set 2 vlan-header=leave-as-is vlan-mode=disabled
set 3 vlan-header=leave-as-is vlan-mode=disabled
set 4 vlan-header=leave-as-is vlan-mode=disabled
set 5 vlan-header=leave-as-is vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:20:F6:14:31:F9 \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=75.<REAL_IP>.<REAL_IP>.129/29 comment=\
"First usable public IP assigend from ComCast" disabled=no interface=\
ether1 network=75.<REAL_IP>.<REAL_IP>.128
add address=75.<REAL_IP>.<REAL_IP>.130/29 comment=\
"Second usable public IP assigend from ComCast" disabled=no interface=\
add address=75.<REAL_IP>.<REAL_IP>.131/29 comment=\
"Third usable public IP assigend from ComCast" disabled=no interface=\
add address=75.<REAL_IP>.<REAL_IP>.132/29 comment=\
"Fourth usable public IP assigend from ComCast" disabled=no interface=\
add address=75.<REAL_IP>.<REAL_IP>.133/29 comment=\
"Fifth usable public IP assigend from ComCast" disabled=no interface=\
add address=192.168.119.1/24 comment="Web services subnet" disabled=no \
interface=ether2 network=192.168.119.0
add address=192.168.120.1/24 comment="BTC mining subnet" disabled=no \
interface=ether3 network=192.168.120.0
add address=192.168.121.1/24 comment="Unassigned subnet" disabled=no \
interface=ether4 network=192.168.121.0
add address=192.168.122.1/24 comment="Home network subnet" disabled=no \
interface=ether5 network=192.168.122.0
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.119.0/24 dhcp-option="" dns-server=4.2.2.2 gateway=\
192.168.119.1 ntp-server="" wins-server=""
add address=192.168.120.0/24 dhcp-option="" dns-server=4.2.2.2 gateway=\
192.168.120.1 ntp-server="" wins-server=""
add address=192.168.121.0/24 dhcp-option="" dns-server=4.2.2.2 gateway=\
192.168.121.1 ntp-server="" wins-server=""
add address=192.168.122.0/24 dhcp-option="" dns-server=4.2.2.2 gateway=\
192.168.122.1 ntp-server="" wins-server=""
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=4096 servers=68.87.68.162
/ip firewall address-list
add address=192.168.119.0/24 disabled=no list="Web services subnet"
add address=192.168.120.0/24 disabled=no list="BTC mining subnet"
add address=192.168.121.0/24 disabled=no list="Unassigned subnet"
add address=192.168.122.0/24 disabled=no list="Home network subnet"
add address=192.168.123.0/24 disabled=no list="Asus BlackKnight subnet"
add address=75.<REAL_IP>.<REAL_IP>.128/29 disabled=no list="ComCast allocated static IPs"
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
"Drop invlaid connections in the forward chain" connection-state=invalid \
disabled=no
"Drop invlaid connections in the input chain" connection-state=invalid \
disabled=no
"Accept traffic to RB from home network subnet" disabled=no \
src-address-list="Home network subnet"
"Accept traffic to RB from wireless subnet" disabled=no src-address-list=\
add action=accept chain=input comment="Accept traffic returned to the RB that \
was established FROM the RB (i.e. a ping or DNS lookup)" \
connection-state=established disabled=no
add action=accept chain=input comment="Accept traffic related to the RB connec\
tins that were established FROM the RB (i.e. a ping or DNS lookup)" \
connection-state=related disabled=no
"Allow connections initiated FROM our web services network to the world" \
connection-state=new disabled=no src-address-list="Web services subnet"
add action=accept chain=forward comment="Allow related connections spawned by \
initiated connections FROM our web services network to the world" \
connection-state=related disabled=no src-address-list=\
add action=accept chain=forward comment="Allow established connections FROM ou\
r web services network to the world" connection-state=established \
"Allow connections initiated FROM our BTC mining network to the world" \
connection-state=new disabled=no src-address-list="BTC mining subnet"
initiated connections FROM our BTC mining network to the world" \
connection-state=related disabled=no src-address-list="BTC mining subnet"
"Allow established connections FROM our BTC mining network to the world" \
connection-state=established disabled=no src-address-list=\
"BTC mining subnet"
"Allow connections initiated FROM our unallocated network to the world" \
connection-state=new disabled=no src-address-list="Unassigned subnet"
initiated connections FROM our unallocated network to the world" \
connection-state=related disabled=no src-address-list="Unassigned subnet"
"Allow established connections FROM our unallocated network to the world" \
"Unassigned subnet"
"Allow connections initiated FROM our Home network to the world" \
connection-state=new disabled=no src-address-list="Home network subnet"
initiated connections FROM our Home network to the world" \
"Allow established connections FROM our Home network to the world" \
add action=accept chain=input comment="Allow new connections FROM the world TO\
\_the IPs and ports used for the DstNat rules to forward web services to t\
he web services subnet" connection-state=new disabled=no \
dst-address-list="ComCast allocated static IPs" protocol=tcp \
src-address-list=0.0.0.0/0 src-port=80,443,25,465,587,143,993,110,995
add action=accept chain=forward comment="Allow established connections FROM th\
e world TO the IPs and ports used for the DstNat rules to forward web serv\
ices to the web services subnet" connection-state=established disabled=no \
add action=accept chain=forward comment="Allow related connections FROM the wo\
rld TO the IPs and ports used for the DstNat rules to forward web services\
\_to the web services subnet" connection-state=related disabled=no \
"Haven't matched any accept rule so drop what remains on the input chain" \
disabled=no
add action=drop chain=forward comment="Haven't matched any accept rule so drop\
\_what remains on the forward chain" disabled=no
add action=src-nat chain=srcnat comment="All internet traffic from the Home ne\
twork subnet will look like it heads out over 75.<REAL_IP>.<REAL_IP>.133" disabled=no \
src-address-list="Home network subnet" to-addresses=75.<REAL_IP>.<REAL_IP>.133
add action=src-nat chain=srcnat comment="All internet traffic from the unalloc\
ated network subnet will look like it heads out over 75.<REAL_IP>.<REAL_IP>.132" \
disabled=no src-address-list="Unassigned subnet" to-addresses=\
add action=src-nat chain=srcnat comment="All internet traffic from the BitCoin\
\_mining network subnet will look like it heads out over 75.<REAL_IP>.<REAL_IP>.131" \
disabled=no src-address-list="BTC mining subnet" to-addresses=\
add action=src-nat chain=srcnat comment="All internet traffic from the web ser\
vices IP 192.168.119.2 will look like it heads out over 75.<REAL_IP>.<REAL_IP>.129. T\
his is so the return traffic heads out the same IP on which it came in." \
disabled=no src-address=192.168.119.2 to-addresses=75.<REAL_IP>.<REAL_IP>.129
add action=dst-nat chain=dstnat comment="DstNat external and inbound TCP port \
80 web traffic to web server on web services subnet" disabled=no \
dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=80 to-addresses=\
192.168.119.2 to-ports=80
443 SSL web traffic to web server on web services subnet" disabled=no \
dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=443 to-addresses=\
192.168.119.2 to-ports=443
53 DNS traffic to DNS server on web services subnet" disabled=no \
dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=53 to-addresses=\
192.168.119.2 to-ports=53
add action=dst-nat chain=dstnat comment="DstNat external and inbound UDP port \
dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=udp src-port=53 to-addresses=\
25 SMTP traffic to PostFix mail server on web services subnet" disabled=\
no dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=25 to-addresses=\
192.168.119.2 to-ports=25
465 SMTPS traffic to PostFix mail server on web services subnet" \
disabled=no dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=465 \
to-addresses=192.168.119.2 to-ports=465
993 IMAPS traffic to imaps server on web services subnet" disabled=no \
dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=993 to-addresses=\
192.168.119.2 to-ports=993
143 IMAP traffic to imap server on web services subnet" disabled=no \
dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=143 to-addresses=\
192.168.119.2 to-ports=143
587 SMTP submission traffic to PostFix mail server on web services subnet" \
disabled=no dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=587 \
to-addresses=192.168.119.2 to-ports=587
110 POP3 traffic to POP3 mail server on web services subnet" disabled=no \
dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=110 to-addresses=\
192.168.119.2 to-ports=110
995 POP3S traffic to POP3S mail server on web services subnet" disabled=\
no dst-address=75.<REAL_IP>.<REAL_IP>.129 protocol=tcp src-port=995 to-addresses=\
192.168.119.2 to-ports=995
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip neighbor discovery
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=75.<REAL_IP>.<REAL_IP>.128 \
scope=30 target-scope=10
/ip service
set telnet address="" disabled=yes port=23
set ftp address="" disabled=yes port=21
set www address="" disabled=yes port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
trap-target="" trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=HomeBorder
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=50.19.122.125 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
400MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=\
"" filter-mac-address="" filter-mac-protocol="" filter-port="" \
filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes \
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
I believe I must be missing a route or I’ve got a nat that is borked but I can’t seem to find it. Any help is GREATLY appreciated. Just to be clear, the problem is that when I startup my laptop and connect to my wireless network I can get to the RB750 and use Winbox but I cannot get to the internet. As well, a linux box I have placed on ehter2 on my web services network also cannot get out to the internet.
Thanks in advance,
James
