I am just starting to learn how to get around in the RouterOS and am trying to create my first script. I found a simple script on the wiki and tried to do some simple things using examples from it. The problem is none of my get commands return any data.
i.e.
[admin@test] > /system package get routeros-mipsbe
[admin@test] >
And some others:
[admin@test] > /system clock get time
[admin@test] > /system clock get date
[admin@test] >
I must be missing something simple, but I have not found it.
Also is there a way to create a file upload it and source it for the script? That would be much easier than the line by line typing I am doing now.
Thanks!
Try this code:
:global test [/system clock get time]
:put $test
This assigns a value (current time) to a variable (test) and then prints it on the command line. Notice when you assign the value to the variable, there is no $, but when you use it, there is. And all script commands start with a colon.
I use the onboard script editor. Cut and paste works, but right-click. Don’t try Control-Y. Only works if you cut from the MT box.
/system script
add name=test
edit test source
Control-o saves and exits
Then in “/system script”, use
run test
That works! Apparently the get command does not echo its output. If I do
:put [/system clock get time]
The time is displayed on the console, but it does not work without the :put.
Anyway, that should get me started.
Thanks!
It should work that way. I just wanted to show you two things at once.
/system script
displays the time here. Insure there is a space between “:put” and “[”.
EDIT: My bad. I see you said it worked that way.
I’ve got a basic script working. I updated the email on ADSL IP change script to work with RouterOS 3.22. I am now working on setting a schedule. The scheduler does not appear to be documented so if you have any pointers I would appreciate it.
Thanks!
The schedule was working even though the script name was showing in red on the console. Many thanks to SurferTim for helping me out.
