Nordlynx server wireguard setup
hello here is my basic configuration range ip local 192.168.88.1 to 192.168.88.253 router ip 192.168.88.254 network to SFP+
user eth1 to eth4 if someone can explain to me the routing to the vpn server wireguard wg0
# feb/20/2022 22:46:04 by RouterOS 7.1
# software id = LFGF-8WF5
# model = RB4011iGS+5HacQ2HnD
add admin-mac=2C:C8:1B:41:41:19 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=\
    20/40/80/160mhz-XXXXXXXX country=france disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik5 \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=france disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=MikroTik-2.4 wireless-protocol=802.11
/interface wireguard
add listen-port=38914 mtu=1420 name=wg0 private-key=\
    "MyKey"
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=123456789 \
    wpa2-pre-shared-key=123456789
add name=dhcp ranges=192.168.88.1-192.168.88.253
add address-pool=dhcp interface=bridge lease-time=1d name=defconf
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf disabled=yes ingress-filtering=no \
    interface=sfp-sfpplus1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
add bridge=bridge ingress-filtering=no interface=ether1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=sfp-sfpplus1 list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=138.199.47.163 endpoint-port=\
    58210 interface=wg0 persistent-keepalive=25s public-key=\
    "FT46M53w4dhBep/2VScW1j/EoZbpBgzvk71FlLZLDBM="
add address=192.168.88.254/24 comment=defconf interface=bridge network=\
    192.168.88.0
add address=10.5.0.2/24 interface=wg0 network=10.5.0.0
/ip dhcp-client
add comment=defconf interface=sfp-sfpplus1
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.254 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.254 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Paris
/system identity
set name=RouterOS
/system leds
add interface=wlan2 leds="wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-le\
    d,wlan2_signal4-led,wlan2_signal5-led" type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/system package update
set channel=long-term
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool mac-server
/tool mac-server mac-winbox
nordlynx.conf work fine to win10 and wireguard.exe software
[Interface]
PrivateKey = ----------------
ListenPort = 38914
Address = 10.5.0.2/24
DNS = 8.8.8.8, 8.8.4.4
[Peer]
PublicKey = FT46M53w4dhBep/2VScW1j/EoZbpBgzvk71FlLZLDBM=
AllowedIPs = 0.0.0.0/0
Endpoint = 138.199.47.163:51820
PersistentKeepalive = 25
cmd get recommendations serveur nordlynx for your connexion:
curl --ssl-no-revoke "https://api.nordvpn.com/v1/servers/recommendations?&filters\[servers_technologies\]\[identifier\]=wireguard_udp&limit=10"|jq -r '.[]|.hostname, .station, (.locations|.[]|.country|.city.name), (.locations|.[]|.country|.name), (.technologies|.[].metadata|.[].value), .load'
What do you want to route? Traffic from whole LAN or from selected devices, traffic to all or selected destinations?
hello I would like to route a list of local addresses see the example below
/ip firewall address-list add address=192.168.88.3 list=allow_ip_nordlynx
/ip firewall address-list add address=192.168.88.8 list=allow_ip_nordlynx
Firewall address lists cannot be used to route traffic through the wireguard tunnel.
However, assuming you wish to push those two users out nordlyx for all internet traffic.
Then
MT Peer setttings: ( you have this correct )
Allowed IPs =0.0.0.0/0
Required is how to force just those two IP addresses to wireguard for internet traffic. 3 Steps:
/routing table add name=useWG0 fib
dst-address=0.0.0.0/0 gateway=wg0 table=useWG0
/routing rule src-address=192.168.88.3/32 action=lookup-only-in-table table=useWG0
/routing rule src-address=192.168.88.8/32 action=lookup-only-in-table table=useWG0
thank you but it does not work it is possible to debug the wireguard connection log
Two things to look at.
  1. Latest config with changes
  2. Picture of your winbox IP RoUTES (and cover any public IPs or gateway IPs like with eraser in paint )
WAN, is wrong. Create one dedicated to WireGuard and use it. You can use connection marking to force choosen clients through that Interface in NAT.
well I have just managed to make the wireguard work with nordlynx fat to you and I thank you very much I you but below the correct parameters
“Private_key”
add allowed-address=0.0.0.0/0 endpoint-address=37.19.217.30 endpoint-port=
51820 interface=wg0 persistent-keepalive=25s public-key=
“FT46M53w4dhBep/2VScW1j/EoZbpBgzvk71FlLZLDBM=”
add action=masquerade chain=srcnat comment=“defconf: allow wireguard”
out-interface=wg0
/routing table
add fib name=useWG0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wg0 pref-src=“”
routing-table=useWG0 scope=30 suppress-hw-offload=no target-scope=10
/routing rule
add action=lookup-only-in-table disabled=no src-address=192.168.88.1/32
table=useWG0
Not exactly true, it’s possible with mangle rules. But if it’s for whole addresses (not just selected ports), I’d probably prefer routing rules too.
Not necessarily, it will work if WG interface is added in WAN interface list. Which could be good choice, because it’s basically untrusted WAN interface anyway.
WHAT? Hmmmmmm
He wants to send two IPs on his local LAN through a third party wireguard provider , for internet access.
This is not rocket science.
(1) The allowed IPs on the MT peer setting must include 0.0.0.0/0 as valid destination addresses that will come from those two IPs.
(2) We use the FORCE tactic as already described.
routing table / IP Route / Route rule for each IP address.
(3) If required a firewall rule could be required depending
add chain=forward action=accept src-address-list=ChosenIPs out-interface=wgInterfaceName
What is missing here, dont think to hard. NOTHING!!!
Did I say that anything is missing? No, I didn’t. I just corrected your claim that address list can’t be used for this.
Yes, let me add caveats for the nitpicky types.
a. firewall address list is handy for any firewall rules involving wg traffic
b. firewall address lists are not used in WG routes, unless one has to use MANGLING, (and then your config is so evil it should be banned anyway… )
Hello my configuration still works very well is it possible to add a killswitch on wireguard
I am using PPPoE to connect. The gateway of the dynamic created Wireguard routing is the PPPoE. Is then Wireguard not also protected by the WAN being not trusted?
My basic killswitch:
/ip/route add blackhole disabled=no distance=254 dst-address=0.0.0.0/0 gateway="" pref-src="" routing-table=exampleRoutingMark-wireguard scope=30 suppress-hw-offload=no \
    target-scope=10
You need to routing-mark traffic. As example, I used “exampleRoutingmarkWireguard”
Update: if I am correct you use: “useWG0”.
HI msmatter, that looks interesting but I dont understand.
a. what is a killswitch
b. how do you invoke it, get it to fire, action, work??? Im assuming you dont ask Alexa :wink:
c. what does your rule in effect do?
hello a killswitch detects if the vpn is disconnected and switches to the default route to always have an operational internet connection
Hmmm interesting.
I will give you one example.
(1) Going out Remote device for internet: The most obvious example then would be I have two subnets vlan10 and vlan11.
Vlan10 is supposed to go out standard internet (local WANIP) and we want vlan11 to enter WG tunnel and go out remote device WANIP.
Besides Firewall rules etc…
dst-address=0.0.0.0/0 gwy=wanipgateway table=main { sends all vlan 10 and vlan 11 traffic out the local wan }
But now we want to send vlan11 only out the tunnel and thus need 3 steps to accomplish this!
/routing table add name=useWG fib
/ip route dst-address=0.0.0.0/0 gwy=wg-Interface-Name table=useWG
/routing rule interface=vlan11 action=lookup-only-in-table table=useWG
With the above rules in place, normally we select action to ONLY in TABLE. If there is no vpn, vlan 11 gets no internet!!
However if we use only LOOKUP, then its the same as a killswitch (assuming your definition is correct). IF the wg tunnel is not up, the users will be directed to the next available table which is table main and the vlan11 users would go out the local WANIP.
Done!!!
My definition of Kill-switch is that unencrypted traffic is not getting out. If the VPN goes down then traffic on the way out, which is not encrypted and that should not happen. All that traffic is destroyed before able to get out of the router.
If you are redirecting it then that is a fail-over. I use that also but the last stop is always a destruction if all fails.
a) See above
b) if VPN is not working then the dynamic routing line is removed by the router, leaving the static rule I stated to handle that traffic.
c) it blackholes that traffic by destroying it.
