I followed the guide
https://help.mikrotik.com/docs/display/ROS/IKEv2+EAP+between+NordVPN+and+RouterOS
but the tunnel doesn’t even try to connect. There is no trace of any connection attempts in the log and I can’t see any active peer.
Everything else is perfectly working.
# 2024-08-15 12:46:18 by RouterOS 7.15.1
# software id = Z8TX-W3QA
# model = RB750Gr3
# serial number = ...
add admin-mac=18:FD:74:2A:C1:D1 auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] comment=ONT
set [ find default-name=ether2 ] advertise=\
10M-baseT-half,10M-baseT-full,1G-baseT-half,1G-baseT-full comment=\
"LAN1 (principale)"
set [ find default-name=ether3 ] comment="LAN2 (secondaria)"
/interface vlan
add comment="ISP Dati" interface=ether1 name=vlan-internet vlan-id=35
add comment="ISP Voce" interface=ether1 name=vlan-voce vlan-id=38
/interface pppoe-client
add disabled=no interface=vlan-internet name=PPPoE_Internet use-peer-dns=yes \
user=...
add disabled=no interface=vlan-voce name=PPPoE_Voce user=...
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip ipsec mode-config
add connection-mark=NordVPN name=NordVPN responder=no use-responder-dns=no
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add name=NordVPN
/ip ipsec peer
add address=it284.nordvpn.com exchange-mode=ike2 name=NordVPN profile=NordVPN
/ip ipsec proposal
add name=NordVPN pfs-group=none
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ip smb users
/port
set 0 name=serial0
/routing table
add disabled=no fib name=to_internet
add disabled=no fib name=to_voce
/system logging action
add name=RemoteLog remote=192.168.0.180 syslog-facility=local0 target=remote
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
set udp-timeout=10s
/ipv6 settings
add comment=defconf interface=vlan-internet list=WAN
/interface ovpn-server server
set auth=sha1,md5
192.168.88.0
/ip arp
add address=192.168.88.251 interface=bridge mac-address=BC:83:85:AF:D3:75
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.89.0/24 gateway=192.168.89.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
/ip firewall address-list
add action=accept chain=input comment="XBOX port for Open NAT" dst-port=3074 \
in-interface=PPPoE_Internet protocol=udp
established,related,untracked
invalid
in-interface-list=!LAN
add action=accept chain=forward dst-address-list=!VPN src-address-list=VPN
add action=accept chain=forward dst-address-list=VPN src-address-list=!VPN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-mark=!NordVPN connection-state=established,related hw-offload=\
yes
connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address-list=VPN \
new-connection-mark=NordVPN passthrough=yes
add action=change-mss chain=forward dst-address-list=VPN new-mss=1350 \
out-interface=all-ethernet passthrough=yes protocol=tcp tcp-flags=syn \
tcp-mss=!0-1350
add action=mark-routing chain=prerouting dst-address=!192.168.88.252 \
new-routing-mark=to_internet passthrough=yes src-address=192.168.88.0/24
add action=mark-routing chain=prerouting dst-address=!192.168.88.0/24 \
new-routing-mark=to_voce passthrough=yes src-address=192.168.88.252
out-interface=PPPoE_Internet src-address=!192.168.88.252
out-interface=PPPoE_Voce src-address=192.168.88.252
add action=dst-nat chain=dstnat comment="PF to XBOX" dst-port=3074 \
in-interface=PPPoE_Internet protocol=udp to-addresses=192.168.88.251
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=\
port-strict mode-config=NordVPN peer=NordVPN policy-template-group=\
NordVPN username=...
/ip ipsec policy
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=\
0.0.0.0/0 template=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=PPPoE_Internet \
routing-table=to_internet scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=PPPoE_Voce \
routing-table=to_voce scope=30 suppress-hw-offload=no target-scope=10
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/routing bfd configuration
add disabled=no
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=RouterOS
/system logging
add action=RemoteLog topics=system,info,account,error,critical
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/user group
add name=api policy="read,write,api,!local,!telnet,!ssh,!ftp,!reboot,!policy,!\
test,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api"
Thank you in advance.
