I want to have the traffic of all devices connected to a certain ethernet port routed over my NordVPN. The first thing I did was to set up the connection according to the guide: https://wiki.mikrotik.com/wiki/IKEv2_EAP_between_NordVPN_and_RouterOS
But as I want all traffic connected to a certain port (regardless of the LAN IP) I did the following:
- create a bridge
- assign an ethernet port to that bridge
- add a DHCP server/pool/network to that bridge (192.x.x.x/24)
- add a Mangle rule:
chain: prerouting
src-address: 192.x.x.x/24
action: mark-connection
connection-mark: nordvpn-mark
So it should work right? Traffic seems to be going to NordVPN, a check of my external IP confirms that. However when I do a speedtest the upload test will “hang” at 0.0mbps. I tried several, none seem to work. On my own server I have a simple PHP “upload file” script, tried to upload a file but after a wile I get a 408 - timeout. It looks like I cannot send traffic over the VPN connection? But then again I can ping addresses and I can use the internet (seems to be slow even though my download is ~100mbps over VPN).
I think I am missing something here, does anybody perhaps have done the same I’m trying to get to work? Please let me know if uploads work for you!
