Nortel VPN and one to one Nat
I have a client trieng to connect to a bank via a Nortel VPN client that uses ipsec. I use hotspot set-up for all the clients that are connected through wireless AP.
I setup a 1 to 1 nat to a public ip in hopes of bypassing the firewall and letting the connection go through. When the user tries to connection, i see on the firewall;; > connections tab, the client using protocol 50, udp 500 connecting to the correct destination. But the vpn session is not established.
I tried 1 to 1 nat becasue using the gre and p2tp helpers did not work for the client.
In the configuration of the 1 to 1 nat, should I set up rules for each protocpl tcp, nat, ipsec ?
Is there a way to completely by-pass the firewall in MT for just one client?
How else can i get the vpn up?
regards,
Robert Macri
yes,
i have simple VPN establised connection MT and user-manger as radius connect from my XP over dialup modem, but some time other isp closed any ports.
i used this methode for control over public to get private address.
regards
Hasbullah.com
