Not able to login with mac address on Mikrotik iOS app
Hello everyone,
Since I started my mikrotik configuration for my house I was not able so far to login with my main router mac address on ios mikrotik app.
I’m using a RB4011iGS main router configured by a specialist but, I can connect to it from a windows computer, using WinBox and the mac address. This way it works.
If I try the same thing, connect through ios Mikrotik app, using the mac address, I get connection refused. Nothing is logged in the log files.
The router was configured so that you can login only using mac address.
Anything I’m doing wrong so that I can connect using the ios mikrotik app?
Thanks in advance for your help!
