New to Mikrotik and been trying to figure out this for a while and nothing worked. I have 2 different subnets running. One subnet is 10.10.0.0/24(ether10) and the other is 192.168.0.0/24(ether5). Both have different ISP’s running. I am trying to ping 192.168.0.x from 10.0.0.x and it does not ping. I need to do this so that people in the office can access the file server which in 192.168.0.10. Below is my export. Any help will be appreciated. Thanks!
set [ find default-name=ether7 ] master-port=ether10
set [ find default-name=ether8 ] master-port=ether10
add name=dhcp-pool ranges=192.168.0.10-192.168.0.254
add name=airtel-dhcp ranges=10.0.0.10-10.0.0.254
add name=pool1 ranges=10.10.0.10-10.10.0.254
add name=pool2 ranges=10.20.0.10-10.20.0.254
add name=pool3 ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp-pool disabled=no interface=ether5 name=dhcp
add address-pool=airtel-dhcp interface=ether7 name=airteldhcp
add address-pool=airtel-dhcp disabled=no interface=ether10 name=Unifi
# DHCP server can not run on slave interface!
add address-pool=pool1 disabled=no interface=ether1 name=airtel2
add address-pool=pool1 interface=ether2 name=server1
add address=203.110.84.178/29 interface=ether4 network=203.110.84.176
add address=192.168.0.1/24 interface=ether5 network=192.168.0.0
add address=10.0.0.1/24 interface=ether7 network=10.0.0.0
add address=10.0.0.1/24 interface=ether10 network=10.0.0.0
add address=10.10.0.1/24 interface=ether1 network=10.10.0.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ether6
interface=ether2
add default-route-distance=0 disabled=no interface=ether3
/ip dhcp-server lease
add address=10.0.0.201 client-id=\
ff:40:56:63:a2:0:2:0:0:ab:11:68:e8:aa:59:c6:87:60:ee mac-address=\
C4:E9:84:01:D0:27 server=Unifi
add address=192.168.0.10 client-id=\
ff:cb:39:a:c7:0:2:0:0:ab:11:68:e8:aa:59:c6:87:60:ee mac-address=\
B8:97:5A:62:39:E1 server=dhcp
add address=10.0.0.0/24 dns-server=192.168.0.1 gateway=10.0.0.1
add address=10.10.0.0/24 dns-server=192.168.0.1 gateway=10.10.0.1
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4,192.168.0.1
/ip dns static
add address=192.168.0.10 name=files.periscope.com
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=DellDsl passthrough=\
no src-address=192.168.0.0/24
add action=mark-routing chain=prerouting new-routing-mark=airtel passthrough=\
yes src-address=10.0.0.0/24
add action=accept chain=prerouting dst-address=192.168.0.1 src-address=\
192.168.0.0/24
add action=accept chain=prerouting dst-address=10.0.0.1 src-address=10.0.0.0/24
add action=masquerade chain=srcnat out-interface=ether4
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.0.16 \
out-interface=all-ethernet protocol=tcp src-address=192.168.0.0/24
add action=dst-nat chain=dstnat dst-address=203.110.84.178 dst-address-list="" \
dst-port=3999 in-interface=ether4 protocol=tcp to-addresses=192.168.0.16 \
to-ports=3999
add action=dst-nat chain=dstnat dst-port=554 in-interface=ether4 protocol=tcp \
to-addresses=192.168.0.16 to-ports=554
add action=dst-nat chain=dstnat dst-port=443 in-interface=ether4 protocol=tcp \
to-addresses=192.168.0.16 to-ports=443
add action=dst-nat chain=dstnat dst-port=8000 in-interface=ether4 protocol=tcp \
to-addresses=192.168.0.16 to-ports=8000
add action=masquerade chain=srcnat out-interface=ether6
add action=masquerade chain=srcnat out-interface=ether2
add action=masquerade chain=srcnat out-interface=ether3
add distance=1 gateway=203.110.84.177 routing-mark=DellDsl
add distance=1 gateway=172.16.16.16 routing-mark=airtel
add disabled=yes distance=1 gateway=203.110.84.177
add disabled=yes distance=1 dst-address=0.0.0.0/32 gateway=172.16.16.16
/lcd
set backlight-timeout=never
/lcd interface
set sfp1 disabled=yes
set ether1 disabled=yes
set ether3 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
