not able to ping my gateway from mikrotik
Hi. I am not able to ping my gateway from microtik. I have ether 1 and 2 and wlan0. The gateway is on my ethernet side. Ether 1.
What steps I have to follow to configure my gateway. Appreciate your quick reply.
Did you add a static route to your gateway? If you did, and still cannot ping, check your firewall filter rules to see if any ICMP packets are not dropped or rejected.
