Not able to post on forum
when i try post a post from home it regularly says “Your IP aaa.bbb.ccc.ddd has been blocked because it is blacklisted. For details please see http://www.spamhaus.org/query/bl?ip=aaa.bbb.ccc.ddd.”. OK, so i go on detail (link to spamhaus) and it says that my IP has no issues.
So I dont know where is problem. can some1 help me with this? I havent seen similar post here
What forum you write about? This forum has nothing common with Spamhouse so maybe you are a victim of somone’s elses activity in your WAN addresses pool?
Hi
yea I meant this forum. When I try to submit post, I get red warning (under “Post a reply” and above post title input text) with text “Your IP xxxx has been blocked because it is blacklisted. For details please see http://www.spamhaus.org/query/bl?ip=xxxx.
Im not sure about this, I have static IP from my provider, so there should be no other with same IP.
Check out why and how to unblock your IP here: https://www.spamhaus.org/faqs/general-questions. Additionally, check if your IP is banned elsewhere using: https://multirbl.valli.org/
Of course not but Spamhouse could block your WAN IP entire eg. /24 pool as there are many other yours “neighbours” spamming/offending.
also if there are open proxies in that ip-pool
Call your ISP ant ask for explanation/help?
Thanks all for help, I wad confused by that error with “you IP is blocked” and with “IP has no Issue”
Yea, I see some black lists my IP is listed in.
I’ll call to my provider and talk about this.
Your ISP won’t be able to sort this out. You need to get in touch with the blocklist providers yourself.
I also recommend that you try to identify and address the source of why your IP was banned. Otherwise, there is a risk that it will happen again.
Yea maybe, but for instance in FAQ you linked there is written that only registered owner of domain/ip should apply for removal
I’m afraid my experience is not enough for this.
I’ve tried https://multirbl.valli.org/ on my cellular data IP and it has even more listings in results and I’m still able post here. Which tests I should run? (FCRDNS & DNSBL lookup / FCRDNS / DNSBL /…)
Maybe I should focus to all devices in my LAN to be sure that problem is not somewhere here
