Not able to reach remote network via vpn between mikrotiks
I set up an openvpn interface to connect with my home and work office. From home, I can ping and access my work network. However, from work, I can only ping my home network from the Mikrotik device. PCs and servers on the 10.10.0.0/16 cannot ping anything on my home network. A traceroute stops at 10.10.1.1.
Any ideas what may be stopping this from working, based on my routing tables?
Home Mikrotik:
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S ;;; added by setup
0.0.0.0/0 public.25 1
1 ADC 10.2.0.0/16 10.2.2.1 ether2 0
2 A S 10.10.0.0/16 10.51.50.101 1
3 ADS 10.51.50.100/30 10.51.50.101 0
4 ADC 10.51.50.101/32 10.51.50.102 ovpn-out1 0
5 ADC public.24/30 public.26 ether1 0
Work Mikrotik:
0 A S 0.0.0.0/0 10.10.1.76 1
1 A S 0.0.0.0/0 10.10.1.76 1
2 A S 0.0.0.0/0 public.1 1
3 A S 5.5.5.0/24 10.10.1.64 1
4 A S 10.2.0.0/16 10.51.50.102 1
5 ADC 10.10.0.0/16 10.10.1.1 ether2 0
6 ADC 10.50.50.6/32 10.50.50.5 0
7 ADC 10.50.50.10/32 10.50.50.9 0
8 ADC 10.50.50.14/32 10.50.50.13 0
9 ADC 10.50.50.22/32 10.50.50.21 0
10 ADC 10.50.50.34/32 10.50.50.33 0
11 ADC 10.50.50.38/32 10.50.50.37 0
12 ADC 10.50.50.42/32 10.50.50.41 0
13 ADC 10.50.50.46/32 10.50.50.45 0
14 ADC 10.50.50.50/32 10.50.50.49 0
15 ADC 10.50.50.82/32 10.50.50.81 0
16 ADC 10.50.50.86/32 10.50.50.85 0
17 ADC 10.50.50.102/32 10.50.50.101 0
18 ADC 10.50.50.106/32 10.50.50.105 0
19 ADC 10.50.50.122/32 10.50.50.121 0
20 ADC 10.50.50.126/32 10.50.50.125 0
21 ADC 10.50.50.134/32 10.50.50.133 0
22 ADC 10.50.50.162/32 10.50.50.161 <ovpn-mrved-int... 0
<ovpn-mrved-int...
23 ADC 10.50.50.174/32 10.50.50.173 0
24 ADC 10.50.50.182/32 10.50.50.181 0
25 ADC 10.50.50.198/32 10.50.50.197 0
26 ADC 10.50.50.210/32 10.50.50.209 0
27 ADC 10.50.50.214/32 10.50.50.213 0
28 ADC 10.50.50.234/32 10.50.50.233 0
29 ADC 10.51.50.2/32 10.51.50.1 0
30 ADC 10.51.50.14/32 10.51.50.13 0
31 ADC 10.51.50.102/32 10.51.50.101 0
32 ADC 10.98.0.0/30 10.98.0.2 verizon1 0
33 ADC 10.98.0.4/30 10.98.0.6 verizon2 0
34 ADb 10.99.0.0/16 10.98.0.1 20
35 Db 10.99.0.0/16 10.98.0.5 20
36 A S 10.198.0.0/20 10.10.2.18 1
37 A S 10.198.80.0/20 10.10.2.6 1
38 A S 10.198.96.0/28 10.10.2.5 1
39 ADC 10.199.1.0/24 10.199.1.1 ether3 0
40 ADC public.0/27 public.6 ether5 0
ether1
ether5
41 ADC public.64/28 public.65 ether8 0
42 ADC public.0/24 public.254 ether4 0
For MikroTik to MikroTik there are much better VPNs than OpenVPN. I would recommend L2TP and you can add IPSec if you need the extra security or SSTP.
Post /export from each of your devices so we can better see the problem. It may not be in your routes, it could be in your firewall or something else.
Home Mikrotik
# jan/06/2015 13:40:25 by RouterOS 4.3
# software id = 72YI-U7G2
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5B:E5:98 \
    master-port=none mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5B:E5:99 \
    master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5B:E5:9A \
    master-port=ether2 mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5B:E5:9B \
    master-port=ether2 mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5B:E5:9C \
    master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1 \
    switch-all-ports=yes
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
    group-key-update=5m interim-update=0s management-protection=disabled \
    management-protection-key="" mode=none name=default \
    radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
    static-sta-private-algo=none static-sta-private-key="" \
    static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
    none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" \
    wpa2-pre-shared-key=""
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
    http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
    name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=\
    3 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des \
    lifetime=30m name=default pfs-group=modp1024
add name=hs-pool-3 ranges=10.5.50.2-10.5.50.254
add name=dhcp_pool1 ranges=10.2.0.1-10.2.2.0
add name=ovpn-pool ranges=10.15.32.34-10.15.32.38
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=\
    static disabled=no interface=ether2 lease-time=30m name=dhcp2
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
    stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default \
    use-compression=default use-encryption=default use-vj-compression=default
add change-tcp-mss=default comment="" local-address=10.15.32.33 name=cc \
    only-one=default remote-address=ovpn-pool use-compression=default \
    use-encryption=required use-vj-compression=default
add change-tcp-mss=default comment="" local-address=10.15.32.5 name=office \
    only-one=default remote-address=10.15.32.6 use-compression=default \
set default-encryption change-tcp-mss=yes comment="" name=default-encryption \
    only-one=default use-compression=default use-encryption=yes \
/interface ovpn-client
add add-default-route=no auth=sha1 certificate=none cipher=aes256 comment="" \
    connect-to=public.30 disabled=no mac-address=00:00:00:00:00:01 max-mtu=\
    1500 mode=ip name=ovpn-out1 password=**lctn port=1194 profile=default \
    user=raymond5
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
    sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
    red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
    5
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
    max-limit=0 name=voip packet-mark=VOIP parent=ether2 priority=2 queue=\
    default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in \
    metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
    auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
    redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=\
    backbone type=default
/snmp
set contact="" enabled=no engine-boots=0 engine-id="" location="" \
    time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=\
    DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
    boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \
    enter-setup-on=any-key force-backup-booter=no
/user group
add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass\
    word,web,sniff,sensitive,!ftp,!write,!policy"
add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb\
    ox,password,web,sniff,sensitive,!ftp,!policy"
add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy\
    ,test,winbox,password,web,sniff,sensitive"
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
set (unknown) vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=cert2 cipher=blowfish128,aes128,aes256 \
    default-profile=default enabled=yes keepalive-timeout=60 mac-address=\
    FE:0F:14:83:55:7D max-mtu=1500 mode=ip netmask=29 port=1194 \
    require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
    no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.2.2.1/16 broadcast=10.2.255.255 comment="" disabled=no \
    interface=ether2 network=10.2.0.0
add address=public.26/30 broadcast=public.27 comment="" disabled=no \
    interface=ether1 network=public.24
/ip dhcp-server config
set store-leases-disk=5m
/ip dhcp-server lease
add address=10.2.0.12 comment="" disabled=no mac-address=F0:A2:25:99:B6:48 \
    server=dhcp2
add address=10.2.0.0/16 comment="" dns-server=10.2.2.1 gateway=10.2.2.1 \
    netmask=16
add address=10.5.50.0/24 comment="hotspot network" gateway=10.5.50.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=512 primary-dns=97.64.168.12 secondary-dns=\
    97.64.183.165
/ip dns static
add address=97.64.168.10 disabled=no name=DNS1 ttl=1d
add address=97.64.183.163 disabled=no name=DNS2 ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
add action=accept chain=forward comment="" disabled=no dst-port=1900 \
    in-interface=ether3 protocol=udp
add action=accept chain=forward comment="" disabled=no dst-port=3306 \
    in-interface=ether3 protocol=tcp
add action=accept chain=forward comment="" disabled=no dst-port=20561 \
    out-interface=ether2 protocol=udp
add action=accept chain=forward comment="" disabled=no out-interface=ether2 \
    protocol=udp src-port=20561
add action=accept chain=forward comment="" disabled=yes in-interface=ether2 \
    out-interface=ether3 port=0-60400 protocol=udp
    out-interface=ether3 port=0-60400 protocol=tcp
add action=accept chain=forward comment="" disabled=yes in-interface=ether3 \
    out-interface=ether2 port=0-60400 protocol=tcp
    out-interface=ether2 port=0-60400 protocol=udp
add action=drop chain=forward comment="" disabled=yes out-interface=ether1 \
    protocol=tcp src-mac-address=00:0E:08:1A:72:E9
    protocol=udp src-address=10.2.0.14
    protocol=tcp src-address=10.2.0.6-10.2.0.10
    protocol=udp src-address=10.2.0.6-10.2.0.10
add action=accept chain=input comment=OpenVPN disabled=yes dst-port=1194 \
    protocol=tcp
    protocol=tcp
add action=accept chain=input comment="" disabled=yes dst-port=22 protocol=\
    tcp src-address=public.0/24
add action=accept chain=forward comment="" disabled=yes dst-address=\
    97.64.138.82 dst-port=22 protocol=tcp
add action=accept chain=forward comment="" disabled=yes protocol=icmp
/ip firewall mangle
add action=change-mss chain=forward comment="" disabled=yes new-mss=1310 \
    protocol=tcp tcp-flags=syn tcp-mss=!0-1448
add action=mark-routing chain=prerouting comment="" disabled=yes \
    new-routing-mark=lctn passthrough=yes protocol=tcp src-address=10.2.0.18
    new-routing-mark=Squid passthrough=yes protocol=tcp src-address=10.2.0.5
add action=mark-routing chain=prerouting comment="" disabled=yes dst-port=80 \
    new-routing-mark=Squid passthrough=yes protocol=tcp src-address=10.2.0.20
add action=mark-routing chain=prerouting comment="" disabled=yes dst-port=443 \
    new-routing-mark=Squid passthrough=yes protocol=tcp src-address=10.2.0.13
add action=src-nat chain=srcnat comment="" disabled=yes dst-port=80 protocol=\
    tcp src-address=10.2.0.5 to-addresses=public.5 to-ports=80
add action=src-nat chain=srcnat comment="" disabled=no out-interface=ether1 \
    src-address=10.2.0.0/16 to-addresses=public.26
add action=src-nat chain=srcnat comment="masquerade hotspot network" \
    disabled=no out-interface=ether1 src-address=10.5.50.0/24 to-addresses=\
    public.26
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=\
    public.26 dst-port=8898 protocol=tcp to-addresses=10.2.2.70 \
    to-ports=80
    public.26 dst-port=5060-5082 protocol=udp to-addresses=10.2.2.70 \
    to-ports=5060-5082
    public.26 dst-port=10000-20000 protocol=udp to-addresses=10.2.2.70 \
    to-ports=10000-20000
    public.26 dst-port=8088 protocol=tcp to-addresses=10.2.0.3 to-ports=\
    8088
    public.26 dst-port=4569 protocol=udp to-addresses=10.2.2.70 \
    to-ports=4569
    public.26 dst-port=3389 protocol=tcp to-addresses=10.2.0.11 \
    to-ports=3389
    public.26 dst-port=80 protocol=tcp to-addresses=10.2.0.15 to-ports=\
    80
    public.26 dst-port=8181 protocol=tcp to-addresses=10.2.0.32 \
    to-ports=8181
    public.26 dst-port=8001 protocol=tcp to-addresses=10.2.0.17 \
    to-ports=8001
    public.26 dst-port=631 protocol=tcp to-addresses=10.2.2.25 to-ports=\
    631
    public.26 dst-port=5900 protocol=tcp src-address=public.0/24 \
    to-addresses=10.2.0.11 to-ports=5900
    public.26 dst-port=515 protocol=tcp to-addresses=10.2.2.25 to-ports=\
    515
    public.26 dst-port=9100 protocol=tcp to-addresses=10.2.2.25 \
    to-ports=9100
    public.26 dst-port=22 protocol=tcp to-addresses=10.2.0.11 to-ports=\
    22
    public.26 dst-port=80 protocol=tcp src-address=64.8.170.117 \
    to-addresses=10.2.0.11 to-ports=80
    public.26 dst-port=32400 protocol=tcp to-addresses=10.2.0.11 \
    to-ports=32400
    public.26 dst-port=8000 protocol=tcp src-address=public.0/24 \
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip hotspot user
add comment="" disabled=no name=admin password=**lctn profile=default
add comment="" disabled=no name=tami password=**lctn profile=default
add comment="" disabled=no name=tim password=**lctn profile=default
add comment="" disabled=no name=gavin password=**lctn profile=default
/ip hotspot walled-garden
add action=allow comment="place hotspot rules here" disabled=yes
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set ovpn-out1 discover=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
add comment="added by setup" disabled=no distance=1 dst-address=0.0.0.0/0 \
    gateway=public.25 scope=30 target-scope=10
add comment="" disabled=no distance=1 dst-address=10.10.0.0/16 gateway=\
    10.51.50.101 scope=30 target-scope=10
/ip service
set telnet address=public.0/24 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=yes port=21
set www address=0.0.0.0/0 disabled=yes port=80
set ssh address=0.0.0.0/0 disabled=yes port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=no port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=ether1 type=external
add disabled=no interface=ether2 type=internal
add disabled=no interface=ether3 type=external
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/ppp secret
add caller-id="" comment="" disabled=no limit-bytes-in=0 limit-bytes-out=0 \
    name=tamray password=tamray1245 profile=office routes="" service=any
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
set ovpn-out1 queue=default
/radius incoming
set accept=no port=3799
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=America/Chicago
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=commando
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=173.255.230.140 secondary-ntp=\
    0.0.0.0
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
    filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=\
    yes interface=ether2 memory-limit=1000 memory-scroll=no only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Work Mikrotik
# jan/06/2015 13:40:41 by RouterOS 6.24
# software id = XDXY-4IRN
add mtu=1500 name=105 protocol-mode=none
add mtu=1500 name=bridge1 protocol-mode=none
add mtu=1500 name=bridge2 protocol-mode=none
set [ find default-name=ether1 ] l2mtu=1590 mac-address=00:0C:42:BD:DC:1C
set [ find default-name=ether2 ] l2mtu=1590 mac-address=00:0C:42:BD:DC:1D
set [ find default-name=ether3 ] l2mtu=1590 mac-address=00:0C:42:BD:DC:1E
set [ find default-name=ether4 ] l2mtu=1590
set [ find default-name=ether5 ] l2mtu=1590 mac-address=00:0C:42:55:1C:A3
set [ find default-name=ether6 ] l2mtu=1590
set [ find default-name=ether7 ] disabled=yes l2mtu=1590
set [ find default-name=ether8 ] l2mtu=1590 mac-address=00:50:04:62:28:76
set [ find default-name=ether9 ] disabled=yes l2mtu=1590 mac-address=\
    00:0B:DB:2E:86:AD
set [ find default-name=ether10 ] l2mtu=1590
set [ find default-name=ether11 ] l2mtu=1590
set [ find default-name=ether12 ] disabled=yes l2mtu=1590
set [ find default-name=sfp1 ] auto-negotiation=no l2mtu=1590
set [ find default-name=sfp2 ] auto-negotiation=no l2mtu=1590
set [ find default-name=sfp3 ] auto-negotiation=no l2mtu=1590
set [ find default-name=sfp4 ] auto-negotiation=no l2mtu=1590
/interface eoip
add clamp-tcp-mss=no mac-address=02:AA:7C:C5:BB:BE mtu=1500 name=Hutch-sc \
    remote-address=10.50.50.146 tunnel-id=32
add clamp-tcp-mss=no mac-address=02:56:1A:EA:1C:50 mtu=1500 name=Maccray-HD \
    remote-address=10.50.50.58 tunnel-id=13
add clamp-tcp-mss=no mac-address=02:FA:24:39:98:10 mtu=1500 name=Roamer-2 \
    remote-address=10.50.50.10 tunnel-id=2
add clamp-tcp-mss=no mac-address=02:A2:63:12:F8:A1 mtu=1500 name=Roamer-3 \
    remote-address=10.50.50.14 tunnel-id=3
add clamp-tcp-mss=no mac-address=02:AB:6D:08:DC:31 mtu=1500 name=Roamer-4 \
    remote-address=10.50.50.18 tunnel-id=4
add clamp-tcp-mss=no mac-address=02:02:D2:F2:44:89 mtu=1500 name=Roamer-5 \
    remote-address=10.50.50.22 tunnel-id=5
add clamp-tcp-mss=no mac-address=02:97:B4:7A:8F:5B mtu=1500 name=Roamer-6 \
    remote-address=10.50.50.26 tunnel-id=6
add clamp-tcp-mss=no mac-address=02:8D:88:71:02:5F mtu=1500 name=Roamer-7 \
    remote-address=10.50.50.34 tunnel-id=7
add clamp-tcp-mss=no mac-address=02:EC:1C:D6:3F:6A mtu=1500 name=Roamer-8 \
    remote-address=10.50.50.38 tunnel-id=8
add clamp-tcp-mss=no mac-address=02:EA:C3:34:95:D7 mtu=1500 name=Roamer-9 \
    remote-address=10.50.50.42 tunnel-id=9
add clamp-tcp-mss=no mac-address=02:18:D7:E1:1C:4A mtu=1500 name=Roamer-10 \
    remote-address=10.50.50.46 tunnel-id=10
add clamp-tcp-mss=no mac-address=02:2B:4D:E2:96:7A mtu=1500 name=Roamer-11 \
    remote-address=10.50.50.50 tunnel-id=11
add clamp-tcp-mss=no mac-address=02:93:8E:94:87:53 mtu=1500 name=Roamer-12 \
    remote-address=10.50.50.55 tunnel-id=12
add clamp-tcp-mss=no mac-address=02:44:6A:58:3F:7F mtu=1500 name=Roamer-14 \
    remote-address=10.50.50.62 tunnel-id=14
add clamp-tcp-mss=no mac-address=02:3F:E5:86:AE:4C mtu=1500 name=Roamer-15 \
    remote-address=10.50.50.74 tunnel-id=15
add clamp-tcp-mss=no mac-address=02:04:C2:C4:6B:C7 mtu=1500 name=Roamer-16 \
    remote-address=10.50.50.78 tunnel-id=16
add clamp-tcp-mss=no mac-address=02:BF:9C:A8:2B:8C mtu=1500 name=Roamer-17 \
    remote-address=10.50.50.82 tunnel-id=17
add clamp-tcp-mss=no mac-address=02:83:38:13:BE:18 mtu=1500 name=Roamer-18 \
    remote-address=10.50.50.86 tunnel-id=18
add clamp-tcp-mss=no mac-address=02:72:C7:D5:A6:5B mtu=1500 name=Roamer-19 \
    remote-address=10.50.50.90 tunnel-id=19
add clamp-tcp-mss=no mac-address=02:BE:69:AC:06:4F mtu=1500 name=Roamer-20 \
    remote-address=10.50.50.94 tunnel-id=20
add clamp-tcp-mss=no mac-address=02:AA:CA:D4:FF:A0 mtu=1500 name=Roamer-21 \
    remote-address=10.50.50.98 tunnel-id=21
add clamp-tcp-mss=no mac-address=02:68:61:FF:FD:A5 mtu=1500 name=Roamer-22 \
    remote-address=10.50.50.102 tunnel-id=22
add clamp-tcp-mss=no mac-address=02:DD:EB:45:2A:9C mtu=1500 name=Roamer-23 \
    remote-address=10.50.50.106 tunnel-id=23
add clamp-tcp-mss=no mac-address=02:56:02:31:AC:B4 mtu=1500 name=Roamer-24 \
    remote-address=10.50.50.110 tunnel-id=24
add clamp-tcp-mss=no mac-address=02:15:CD:80:66:76 mtu=1500 name=Roamer-25 \
    remote-address=10.50.50.114 tunnel-id=25
add clamp-tcp-mss=no mac-address=02:37:FF:77:49:AB mtu=1500 name=Roamer-26 \
    remote-address=10.50.50.118 tunnel-id=26
add clamp-tcp-mss=no mac-address=02:DA:33:A1:B5:74 mtu=1500 name=Roamer-27 \
    remote-address=10.50.50.122 tunnel-id=27
add clamp-tcp-mss=no mac-address=02:C3:04:EA:6C:45 mtu=1500 name=Roamer-29 \
    remote-address=10.50.50.130 tunnel-id=29
add clamp-tcp-mss=no mac-address=02:21:46:65:B1:54 mtu=1500 name=Roamer-30 \
    remote-address=10.50.50.134 tunnel-id=30
add clamp-tcp-mss=no mac-address=02:FD:38:D8:8E:94 mtu=1500 name=Roamer-31 \
    remote-address=10.50.50.138 tunnel-id=31
add mac-address=02:56:BE:98:36:3F mtu=1500 name=Roamer-32 remote-address=\
    10.51.50.42 tunnel-id=5141
add clamp-tcp-mss=no mac-address=02:7F:87:1F:72:21 mtu=1500 name=acgc-elem \
    remote-address=10.50.50.170 tunnel-id=169
add clamp-tcp-mss=no mac-address=02:E7:B3:38:05:B9 mtu=1500 name=acgc-hd \
    remote-address=10.50.50.158 tunnel-id=36
add clamp-tcp-mss=no mac-address=02:B5:DB:F7:E0:33 mtu=1500 name=acgc-sc \
    remote-address=10.50.50.222 tunnel-id=221
add clamp-tcp-mss=no mac-address=02:3C:D1:1A:E2:F7 mtu=1500 name=bbe-elem \
    remote-address=10.50.50.174 tunnel-id=173
add clamp-tcp-mss=no mac-address=02:5D:B7:F1:8F:E8 mtu=1500 name=bbe-sc \
    remote-address=10.50.50.154 tunnel-id=34
add clamp-tcp-mss=no mac-address=02:34:02:0C:8D:B7 mtu=1500 name=blh-elem \
    remote-address=10.50.50.182 tunnel-id=181
add mac-address=02:8C:90:CA:16:6C mtu=1500 name=blh-hd remote-address=\
    10.50.50.82 tunnel-id=81
add clamp-tcp-mss=no mac-address=02:6A:9A:BF:03:32 mtu=1500 name=bold-elem \
    remote-address=10.50.50.178 tunnel-id=177
add clamp-tcp-mss=no mac-address=02:22:99:C2:10:FF mtu=1500 name=bold-sc \
    remote-address=10.51.50.14 tunnel-id=5113
add clamp-tcp-mss=no mac-address=00:00:5E:80:00:01 mtu=1500 name=eoip-tunnel1 \
    remote-address=10.50.50.6 tunnel-id=1
add clamp-tcp-mss=no mac-address=02:4E:B8:50:BB:50 mtu=1500 name=gsl-elem \
    remote-address=10.50.50.186 tunnel-id=185
add clamp-tcp-mss=no mac-address=02:BC:39:EB:8B:75 mtu=1500 name=gsl-sc \
    remote-address=10.50.50.166 tunnel-id=165
add clamp-tcp-mss=no mac-address=02:CD:66:F8:A9:5E mtu=1500 name=hutch-ms \
    remote-address=10.50.50.194 tunnel-id=193
add clamp-tcp-mss=no mac-address=02:C8:65:50:29:A0 mtu=1500 name=hutch-park \
    remote-address=10.50.50.242 tunnel-id=241
add clamp-tcp-mss=no mac-address=02:43:CE:FA:A5:C6 mtu=1500 name=kennedy \
    remote-address=10.51.50.2 tunnel-id=5112
add clamp-tcp-mss=no mac-address=02:6A:97:07:3E:4A mtu=1500 name=kennedy2 \
    remote-address=10.51.50.22 tunnel-id=5121
add clamp-tcp-mss=no mac-address=02:24:C8:97:01:9B mtu=1500 name=\
    lakeview-elem remote-address=10.50.50.206 tunnel-id=205
add clamp-tcp-mss=no mac-address=02:7C:8A:94:58:64 mtu=1500 name=lester-hd \
    remote-address=10.50.50.126 tunnel-id=28
add clamp-tcp-mss=no mac-address=02:75:94:07:7A:95 mtu=1500 name=lp-elem \
    remote-address=10.50.50.202 tunnel-id=201
add clamp-tcp-mss=no mac-address=02:9F:40:8F:91:AE mtu=1500 name=maynard \
    remote-address=10.50.50.198 tunnel-id=197
add clamp-tcp-mss=no mac-address=02:AC:36:CF:93:92 mtu=1500 name=monte-elem \
    remote-address=10.50.50.218 tunnel-id=217
add mac-address=02:C6:A5:86:27:BC mtu=1500 name=monte-sup remote-address=\
    10.50.50.214 tunnel-id=213
add clamp-tcp-mss=no mac-address=02:7C:03:66:27:3B mtu=1500 name=mrved-sc \
    remote-address=10.50.50.150 tunnel-id=33
add clamp-tcp-mss=no mac-address=02:EB:78:15:74:2A mtu=1500 name=murdock \
    remote-address=10.50.50.230 tunnel-id=229
add clamp-tcp-mss=no mac-address=02:F0:2E:C2:C0:27 mtu=1500 name=nls-elem \
    remote-address=10.50.50.234 tunnel-id=233
add clamp-tcp-mss=no mac-address=02:2D:83:EC:4E:35 mtu=1500 name=ort-hd \
    remote-address=10.51.50.10 tunnel-id=519
add clamp-tcp-mss=no mac-address=02:26:38:6D:F3:3B mtu=1500 name=yme-elem \
    remote-address=10.50.50.210 tunnel-id=209
/interface gre
add clamp-tcp-mss=no dscp=0 local-address=public.30 mtu=1476 name=verizon1 \
    remote-address=66.174.192.198
add clamp-tcp-mss=no dscp=0 local-address=public.30 mtu=1476 name=verizon2 \
    remote-address=66.174.200.11
/ip dhcp-server option
add code=150 name=O150 value=0x4A74D2A3
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc
add auth-algorithms=md5 enc-algorithms=aes-256-cbc lifetime=1d name=VZW \
    pfs-group=none
add auth-algorithms=md5 enc-algorithms=aes-256-cbc lifetime=1d name=VZW2 \
    pfs-group=none
add name=dhcp_pool1 ranges=10.10.20.1-10.10.20.254
add name=dhcp_pool2 ranges=10.10.1.50-10.10.255.254
add name=dhcp_pool3 ranges=public.245-public.252
add address-pool=dhcp_pool2 disabled=no interface=ether2 lease-time=3d name=\
    dhcp1
add address-pool=dhcp_pool3 disabled=no interface=ether4 lease-time=3d name=\
    dhcp2
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
set 0 local-address=10.50.50.5 remote-address=10.50.50.6 use-encryption=\
    required
add local-address=10.50.50.9 name=roamer-2 remote-address=10.50.50.10 \
add local-address=10.50.50.13 name=roamer-3 remote-address=10.50.50.14 \
add local-address=10.50.50.17 name=roamer-4 remote-address=10.50.50.18 \
add local-address=10.50.50.21 name=lqpv-hd remote-address=10.50.50.22 \
add local-address=10.50.50.25 name=roamer-6 remote-address=10.50.50.26 \
add local-address=10.50.50.29 name=lctn-xp remote-address=10.50.50.30 \
add local-address=10.50.50.33 name=roamer-7 remote-address=10.50.50.34 \
add local-address=10.50.50.37 name=roamer-8 remote-address=10.50.50.38 \
add local-address=10.50.50.41 name=roamer-9 remote-address=10.50.50.42 \
add local-address=10.50.50.45 name=roamer-10 remote-address=10.50.50.46 \
add local-address=10.50.50.49 name=roamer-11 remote-address=10.50.50.50 \
add local-address=10.50.50.53 name=roamer-12 remote-address=10.50.50.54 \
add local-address=10.50.50.57 name=maccray-hd remote-address=10.50.50.58 \
add local-address=10.50.50.61 name=roamer-14 remote-address=10.50.50.62 \
add local-address=10.50.50.73 name=roamer-15 remote-address=10.50.50.74 \
add local-address=10.50.50.77 name=roamer-16 remote-address=10.50.50.78 \
add local-address=10.50.50.81 name=blh-hd remote-address=10.50.50.82 \
add local-address=10.50.50.85 name=roamer-18 remote-address=10.50.50.86 \
add local-address=10.50.50.89 name=bbe-hd remote-address=10.50.50.90 \
add local-address=10.50.50.93 name=roamer-20 remote-address=10.50.50.94 \
add local-address=10.50.50.97 name=roamer-21 remote-address=10.50.50.98 \
add local-address=10.50.50.101 name=Roamer-22 remote-address=10.50.50.102 \
add local-address=10.50.50.105 name=roamer-23 remote-address=10.50.50.106 \
add local-address=10.50.50.109 name=roamer-24 remote-address=10.50.50.110 \
add local-address=10.50.50.113 name=roamer-25 remote-address=10.50.50.114 \
add local-address=10.50.50.117 name=roamer-26 remote-address=10.50.50.118 \
add local-address=10.50.50.121 name=roamer-27 remote-address=10.50.50.122 \
add local-address=10.50.50.125 name=lester-hd remote-address=10.50.50.126 \
add local-address=10.50.50.129 name=roamer-29 remote-address=10.50.50.130 \
add local-address=10.50.50.133 name=blh-sc remote-address=10.50.50.134 \
add local-address=10.50.50.137 name=acgc remote-address=10.50.50.138 \
add local-address=10.50.50.141 name=roamer-31 remote-address=10.50.50.142 \
add local-address=10.50.50.145 name=Hutch-sc remote-address=10.50.50.146 \
add local-address=10.50.50.149 name=mrved-sc remote-address=10.50.50.150 \
add local-address=10.50.50.153 name=bbe-sc remote-address=10.50.50.154 \
add local-address=10.50.50.157 name=acgc-hd remote-address=10.50.50.158 \
add local-address=10.50.50.161 name=mrved-internet remote-address=\
    10.50.50.162 use-encryption=required
add local-address=10.50.50.233 name=nls-elem remote-address=10.50.50.234
add local-address=10.50.50.197 name=maynard remote-address=10.50.50.198
add local-address=10.50.50.209 name=yme-elem remote-address=10.50.50.210
add local-address=10.50.50.169 name=acgc-elem remote-address=10.50.50.170
add local-address=10.50.50.221 name=acgc-sc remote-address=10.50.50.222
add local-address=10.51.50.9 name=ort-hd remote-address=10.51.50.10
add local-address=10.50.50.181 name=blh-elem remote-address=10.50.50.182
add local-address=10.50.50.205 name=lakeview-elem remote-address=10.50.50.206
add local-address=10.50.50.217 name=monte-elem remote-address=10.50.50.218
add local-address=10.50.50.185 name=gsl-elem remote-address=10.50.50.186
add local-address=10.50.50.165 name=gsl-sc remote-address=10.50.50.166
add local-address=10.51.50.13 name=bold-sc remote-address=10.51.50.14
add local-address=10.50.50.193 name=hutch-ms remote-address=10.50.50.194
add local-address=10.51.50.1 name=kennedy remote-address=10.51.50.2
add local-address=10.50.50.201 name=lp-elem remote-address=10.50.50.202
add local-address=10.50.50.241 name=hutch-park remote-address=10.50.50.242
add local-address=10.51.50.17 name=temp remote-address=10.51.50.18
add local-address=10.50.50.173 name=bbe-elem remote-address=10.50.50.174
add local-address=10.50.50.229 name=murdock remote-address=10.50.50.230
add local-address=10.51.50.21 name=kennedy2 remote-address=10.51.50.22
add local-address=10.50.50.177 name=bold-elem remote-address=10.50.50.178 \
    use-encryption=no
add local-address=10.51.50.29 name=raymond2 remote-address=10.51.50.30
add local-address=10.51.50.33 name=raymond remote-address=10.51.50.34
add local-address=10.51.50.37 name=Neil remote-address=10.51.50.38 \
add local-address=10.51.50.101 name=raymond5 remote-address=10.51.50.102 \
add local-address=10.50.50.213 name=monte-sup remote-address=10.50.50.214 \
add local-address=10.51.50.41 name=Roamer-32 remote-address=10.51.50.42
set default router-id=10.98.0.2
set 0 memory-lines=10000
set 1 disk-lines-per-file=100
set 3 src-address=0.0.0.0
add bridge=bridge1 interface=eoip-tunnel1
add bridge=bridge1 interface=Roamer-2
add bridge=bridge1 interface=acgc-hd
add bridge=bridge1 interface=Roamer-4
add bridge=bridge1 interface=Roamer-5
add bridge=bridge1 interface=Roamer-6
add bridge=bridge1 interface=Roamer-7
add bridge=bridge1 interface=Roamer-11
add bridge=bridge1 interface=Roamer-10
add bridge=bridge1 interface=Roamer-9
add bridge=bridge1 interface=Roamer-8
add bridge=bridge1 interface=Maccray-HD
add bridge=bridge1 interface=Roamer-14
add bridge=bridge1 interface=Roamer-15
add bridge=bridge1 interface=Roamer-16
add bridge=bridge1 interface=Roamer-17
add bridge=bridge1 interface=Roamer-18
add bridge=bridge1 interface=Roamer-20
add bridge=bridge1 interface=Roamer-21
add bridge=bridge1 interface=Roamer-22
add bridge=bridge1 interface=Roamer-23
add bridge=bridge1 interface=Roamer-24
add bridge=bridge1 interface=Roamer-25
add bridge=bridge1 interface=Roamer-26
add bridge=bridge1 interface=Roamer-27
add bridge=bridge1 interface=lester-hd
add bridge=bridge1 interface=Roamer-29
add bridge=bridge1 interface=Roamer-30
add bridge=bridge1 interface=Roamer-12
add bridge=bridge1 interface=Roamer-19
add bridge=bridge1 interface=Roamer-31
add bridge=bridge1 interface=Hutch-sc
add bridge=bridge1 interface=mrved-sc
add bridge=bridge1 interface=bbe-sc
add bridge=bridge1 interface=nls-elem
add bridge=bridge1 interface=maynard
add bridge=bridge1 interface=yme-elem
add bridge=bridge1 interface=acgc-elem
add bridge=bridge1 interface=acgc-sc
add bridge=bridge1 interface=ort-hd
add bridge=bridge1 interface=blh-elem
add bridge=bridge1 interface=lakeview-elem
add bridge=bridge1 interface=monte-elem
add bridge=bridge1 interface=gsl-elem
add bridge=bridge1 interface=gsl-sc
add bridge=bridge1 interface=bold-sc
add bridge=bridge1 interface=hutch-ms
add bridge=bridge1 interface=kennedy
add bridge=bridge1 interface=lp-elem
add bridge=bridge1 interface=hutch-park
add bridge=bridge1 interface=murdock
add bridge=bridge1 interface=kennedy2
add bridge=bridge1 interface=bbe-elem
add bridge=bridge1 interface=bold-elem
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=blh-hd
add bridge=bridge1 interface=monte-sup
add bridge=bridge1 interface=Roamer-32
set auth=sha1 certificate=cert_1 cipher=blowfish128,aes128,aes192,aes256 \
    enabled=yes keepalive-timeout=disabled netmask=30
add address=public.30/27 interface=ether5 network=public.0
add address=public.4/27 interface=ether1 network=public.0
add address=public.3/27 interface=ether1 network=public.0
add address=public.10/27 interface=ether1 network=public.0
add address=public.11/27 interface=ether1 network=public.0
add address=public.12/27 interface=ether1 network=public.0
add address=public.24/27 interface=ether1 network=public.0
add address=public.17/27 interface=ether1 network=public.0
add address=public.18/27 interface=ether1 network=public.0
add address=public.22/27 interface=ether1 network=public.0
add address=public.13/27 interface=ether1 network=public.0
add address=public.7/27 interface=ether1 network=public.0
add address=public.28/27 interface=ether1 network=public.0
add address=10.10.1.1/16 interface=ether2 network=10.10.0.0
add address=public.14/27 interface=ether1 network=public.0
add address=public.15/27 interface=ether1 network=public.0
add address=public.5/27 interface=ether1 network=public.0
add address=public.65/28 interface=ether8 network=public.64
add address=public.2/27 interface=ether1 network=public.0
add address=public.254/24 interface=ether4 network=public.0
add address=10.98.0.2/30 interface=verizon1 network=10.98.0.0
add address=public.29/27 interface=ether1 network=public.0
add address=10.98.0.6/30 interface=verizon2 network=10.98.0.4
add address=10.199.1.1/24 interface=ether3 network=10.199.1.0
add address=public.6/27 interface=ether5 network=public.0
add address=10.10.8.110 client-id=00:50:56:BC:03:35 mac-address=\
    00:50:56:BC:03:35 server=dhcp1
add address=10.10.1.15 mac-address=BC:AE:C5:92:07:C3 server=dhcp1
add address=10.10.1.23 client-id=1:0:50:56:bc:3:20 mac-address=\
    00:50:56:BC:03:20 server=dhcp1
add address=10.10.1.58 client-id=1:d4:85:64:76:9f:90 mac-address=\
    D4:85:64:76:9F:90 server=dhcp1
add address=10.10.1.43 client-id=1:5c:d9:98:b:ed:31 mac-address=\
    5C:D9:98:0B:ED:31 server=dhcp1
add address=10.10.1.19 mac-address=00:50:56:BC:03:17
add address=10.10.1.73 mac-address=00:1A:4B:77:9E:5C server=dhcp1
add address=10.10.1.53 mac-address=00:30:48:72:53:A0 server=dhcp1
add address=10.10.1.99 client-id=1:0:11:32:25:1:1 mac-address=\
    00:11:32:25:01:01 server=dhcp1
add address=10.10.4.14 mac-address=00:11:32:28:71:09
add address=public.36 client-id=E4C722668179 mac-address=E4:C7:22:66:81:79
add address=public.28 client-id=E4C722666A88 mac-address=E4:C7:22:66:6A:88
add address=public.116 client-id=E4C722667744 mac-address=E4:C7:22:66:77:44
add address=public.52 client-id=E4C722667890 mac-address=E4:C7:22:66:78:90
add address=public.92 client-id=E4C72266785A mac-address=E4:C7:22:66:78:5A
add address=public.60 mac-address=E4:C7:22:66:75:DA server=dhcp2
add address=public.167 client-id=E4C7226675CA mac-address=E4:C7:22:66:75:CA
add address=public.156 client-id=E4C72266784C mac-address=E4:C7:22:66:78:4C
add address=public.100 client-id=E4C722667862 mac-address=E4:C7:22:66:78:62
add address=public.44 client-id=E4C722666A67 mac-address=E4:C7:22:66:6A:67
add address=public.84 client-id=E4C72266786B mac-address=E4:C7:22:66:78:6B
add address=public.76 client-id=E4C7226675DB mac-address=E4:C7:22:66:75:DB
add address=public.132 client-id=E4C7226675D8 mac-address=E4:C7:22:66:75:D8
add address=public.133 client-id=E4C722667858 mac-address=E4:C7:22:66:78:58
add address=public.20 client-id=E4C722666B89 mac-address=E4:C7:22:66:6B:89
add address=public.68 client-id=E4C7226675CF mac-address=E4:C7:22:66:75:CF
add address=public.140 client-id=E4C7226675C5 mac-address=E4:C7:22:66:75:C5
add address=public.13 always-broadcast=yes client-id=E4C7226675C6 \
    mac-address=E4:C7:22:66:75:C6
add address=public.150 client-id=E4:C7:22:66:75:EC mac-address=\
    E4:C7:22:66:75:EC server=dhcp2
add address=public.201 always-broadcast=yes client-id=1:2:e9:48:c7:8e:ac \
    mac-address=02:E9:48:C7:8E:AC server=dhcp2
add address=public.108 client-id=E4C72266760A mac-address=E4:C7:22:66:76:0A
add address=10.10.4.23 mac-address=00:0C:29:08:21:CC server=dhcp1
add client-id=1:d4:ca:6d:e4:13:2b mac-address=D4:CA:6D:E4:13:2B server=dhcp2
add address=10.10.0.0/16 dns-server=10.10.4.21 gateway=10.10.1.1
add address=public.0/24 dhcp-option=O150 dns-server=\
    10.250.4.200,10.250.4.201 domain=lctn.private.network gateway=public.1
set allow-remote-requests=yes max-udp-packet-size=512 servers=192.168.88.1
/ip dns static
add address=192.168.88.1 name=router
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 \
    protocol=tcp
add chain=input connection-state=new dst-port=22 protocol=tcp \
    src-address-list=public.0/27
add action=add-src-to-address-list address-list=ssh_stage3 \
    address-list-timeout=1m chain=input connection-state=new dst-port=22 \
    protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
    protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
    protocol=tcp
add chain=input comment="default configuration" protocol=icmp
add chain=forward dst-address=10.199.1.0/24 protocol=icmp src-address=\
    10.10.0.0/16
add action=log chain=input comment="ZeroAccess Log" dst-port=16471 protocol=\
    udp
add action=drop chain=input comment="ZeroAccess botnet" dst-port=16471 \
    protocol=udp
add action=drop chain=output comment="ZeroAccess Outbound" dst-port=16471 \
    protocol=udp
add chain=input log=yes src-address=66.174.192.198
add chain=input dst-port=500 log=yes protocol=udp
add chain=input dst-port=500 log=yes protocol=tcp
add chain=input protocol=ipsec-esp
add action=drop chain=forward dst-address=public.64/29 dst-port=5060 log=\
    yes protocol=udp
add action=drop chain=input log=yes src-address=175.117.145.48
/ip firewall mangle
add action=mark-routing chain=prerouting dst-port=80 new-routing-mark=\
    verizon80 passthrough=no protocol=tcp src-address=10.99.0.0/16
add action=mark-routing chain=prerouting dst-port=443 new-routing-mark=\
    verizon443 passthrough=no protocol=tcp src-address=10.99.0.0/16
add action=src-nat chain=srcnat out-interface=ether5 src-address=10.10.4.25 \
    to-addresses=public.22
add action=src-nat chain=srcnat out-interface=ether5 src-address=10.10.4.13 \
    to-addresses=public.3
add action=src-nat chain=srcnat out-interface=ether5 src-address=10.10.4.8 \
add action=src-nat chain=srcnat src-address=10.10.1.15 to-addresses=\
    public.3
add chain=srcnat dst-address=10.98.0.0/24 out-interface=ether5 src-address=\
    10.10.0.0/16
add action=src-nat chain=srcnat src-address=10.199.1.0/24 to-addresses=\
    public.3
add action=src-nat chain=srcnat out-interface=ether2 src-address=public.3 \
    to-addresses=10.10.1.15
add action=src-nat chain=srcnat src-address=10.10.0.0/16 to-addresses=\
    public.3
add action=masquerade chain=srcnat src-address=10.99.0.0/16 to-addresses=\
    public.3
add action=dst-nat chain=dstnat dst-address=public.2 in-interface=ether5 \
    to-addresses=10.10.4.8
add action=dst-nat chain=dstnat dst-address=public.24 dst-port=25 protocol=\
    tcp to-addresses=10.10.4.23 to-ports=25
add action=dst-nat chain=dstnat dst-address=public.11 dst-port=25 protocol=\
add action=dst-nat chain=dstnat dst-address=public.17 dst-port=25 protocol=\
add action=dst-nat chain=dstnat dst-address=public.18 dst-port=25 protocol=\
add action=dst-nat chain=dstnat dst-address=public.3 dst-port=25 protocol=\
    tcp to-addresses=10.10.4.13 to-ports=25
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=25 protocol=\
add action=dst-nat chain=dstnat dst-address=public.3 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.1 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.3 dst-port=143 protocol=\
    tcp to-addresses=10.10.4.13 to-ports=143
add action=dst-nat chain=dstnat dst-address=public.3 dst-port=443 protocol=\
    tcp to-addresses=10.10.4.13 to-ports=443
add action=dst-nat chain=dstnat dst-address=public.3 dst-port=993 protocol=\
    tcp to-addresses=10.10.4.13 to-ports=993
add action=dst-nat chain=dstnat dst-address=public.3 dst-port=465 protocol=\
    tcp to-addresses=10.10.4.13 to-ports=465
add action=dst-nat chain=dstnat dst-address=public.22 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.27 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.7 dst-port=3389 \
    protocol=tcp to-addresses=10.10.1.23 to-ports=3389
add action=dst-nat chain=dstnat dst-address=public.13 dst-port=80 protocol=\
    tcp to-addresses=10.10.1.83 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.13 dst-port=3389 \
    protocol=tcp to-addresses=10.10.4.39 to-ports=3389
add action=dst-nat chain=dstnat dst-address=public.24 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.15 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.11 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.10 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.18 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.23 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=32400 \
    protocol=tcp to-addresses=10.10.1.15 to-ports=32400
add action=dst-nat chain=dstnat dst-address=public.7 dst-port=5901 \
    protocol=tcp to-addresses=10.10.1.23 to-ports=5901
add action=dst-nat chain=dstnat dst-address=public.7 dst-port=443 protocol=\
    tcp to-addresses=10.10.1.23 to-ports=443
add action=dst-nat chain=dstnat dst-address=public.12 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.9 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.10 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.60 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.10 dst-port=1935 \
    protocol=tcp to-addresses=10.10.4.60 to-ports=1935
add action=dst-nat chain=dstnat dst-address=public.10 dst-port=443 \
    protocol=tcp to-addresses=10.10.4.60 to-ports=443
add action=dst-nat chain=dstnat dst-address=public.10 dst-port=8000 \
    protocol=tcp to-addresses=10.10.4.60 to-ports=8000
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=21 protocol=\
    tcp to-addresses=10.10.4.21 to-ports=21
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=22 protocol=\
    tcp src-address=public.26 to-addresses=10.10.1.15 to-ports=22
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=80 protocol=\
    tcp to-addresses=10.10.1.5 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=443 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=443
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=8800 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=8800
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=123 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=123
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=53 protocol=\
    tcp to-addresses=10.10.1.5 to-ports=53
    udp to-addresses=10.10.1.5 to-ports=53
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=35060 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=35060
    protocol=udp to-addresses=10.10.1.5 to-ports=35060
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=10000-16000 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=10000-16000
    protocol=udp to-addresses=10.10.1.5 to-ports=10000-16000
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=5060 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=5060
    protocol=udp to-addresses=10.10.1.5 to-ports=5060
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=1720 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=1720
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=1719 \
    protocol=udp to-addresses=10.10.1.5 to-ports=1719
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=50000 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=50000
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=55060 \
    protocol=tcp to-addresses=10.10.1.5 to-ports=55060
    protocol=udp to-addresses=10.10.1.5 to-ports=55060
add action=dst-nat chain=dstnat dst-address=public.14 dst-port=50000-55000 \
    protocol=udp to-addresses=10.10.1.5 to-ports=50000-55000
add action=dst-nat chain=dstnat dst-address=public.15 dst-port=80 protocol=\
    tcp to-addresses=10.10.1.19 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.15 dst-port=25 protocol=\
    tcp to-addresses=10.10.1.19 to-ports=25
add action=dst-nat chain=dstnat dst-address=public.7 dst-port=80 protocol=\
    tcp to-addresses=10.10.1.76 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=69 protocol=\
    udp to-addresses=10.10.1.15 to-ports=69
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=3389 \
    protocol=tcp to-addresses=10.10.1.15 to-ports=3389
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=8080 \
    protocol=tcp to-addresses=10.10.1.83 to-ports=8080
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=8181 \
    protocol=tcp to-addresses=10.10.1.83 to-ports=8181
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=80 protocol=\
add action=dst-nat chain=dstnat dst-address=public.5 dst-port=80 protocol=\
    tcp to-addresses=10.10.1.15 to-ports=80
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=9101 \
    protocol=tcp to-addresses=10.10.4.2 to-ports=9101
add action=dst-nat chain=dstnat dst-address=public.10 dst-port=8008 \
    protocol=tcp to-addresses=10.10.4.60 to-ports=8008
add action=dst-nat chain=dstnat dst-address=public.24 dst-port=8000 \
    protocol=tcp to-addresses=10.10.4.5 to-ports=8000
add action=dst-nat chain=dstnat dst-address=public.24 dst-port=554 \
    protocol=tcp to-addresses=10.10.4.15 to-ports=554
add action=dst-nat chain=dstnat dst-address=public.4 dst-port=6544 \
    protocol=tcp to-addresses=10.10.1.83 to-ports=6544
add action=dst-nat chain=dstnat dst-address=public.3 dst-port=32400 \
add action=dst-nat chain=dstnat dst-address=public.2 dst-port=143 protocol=\
    tcp to-addresses=10.10.4.8 to-ports=143
add action=dst-nat chain=dstnat dst-address=public.2 dst-port=993 protocol=\
    tcp to-addresses=10.10.4.8 to-ports=993
add action=dst-nat chain=dstnat disabled=yes dst-address=public.2 dst-port=\
    25 protocol=tcp to-addresses=10.10.4.8 to-ports=25
add action=dst-nat chain=dstnat dst-address=public.2 dst-port=587 protocol=\
    tcp to-addresses=10.10.4.8 to-ports=587
add action=dst-nat chain=dstnat dst-address=public.2 dst-port=465 protocol=\
    tcp to-addresses=10.10.4.8 to-ports=465
    22 protocol=tcp to-addresses=10.10.4.8 to-ports=22
add action=dst-nat chain=dstnat disabled=yes dst-port=80 protocol=tcp \
    src-address=10.10.1.15 to-addresses=10.10.1.76 to-ports=3129
add action=dst-nat chain=dstnat disabled=yes dst-port=443 protocol=tcp \
    src-address=10.10.1.15 to-addresses=10.10.1.76 to-ports=3127
add action=dst-nat chain=dstnat dst-address=public.6 dst-port=80 protocol=\
    tcp to-addresses=10.10.4.26 to-ports=80
add action=src-nat chain=srcnat src-address=5.5.5.0/24 to-addresses=\
    public.3
/ip ipsec peer
add address=66.174.192.198/32 dpd-interval=15s enc-algorithm=aes-256 \
    nat-traversal=no secret=VzWmPn01686 send-initial-contact=no
add address=66.174.200.11/32 dpd-interval=15s enc-algorithm=aes-256 \
/ip ipsec policy
set 0 disabled=yes
add dst-address=66.174.192.198/32 proposal=VZW sa-dst-address=66.174.192.198 \
    sa-src-address=public.30 src-address=public.30/32
add dst-address=66.174.200.11/32 proposal=VZW2 sa-dst-address=66.174.200.11 \
/ip proxy
set cache-path=web-proxy1
/ip proxy access
add dst-port=80 src-address=10.10.1.73
add distance=1 gateway=10.10.1.76 routing-mark=verizon80
add distance=1 gateway=10.10.1.76 routing-mark=verizon443
add distance=1 gateway=public.1
add distance=1 dst-address=5.5.5.0/24 gateway=10.10.1.64
add distance=1 dst-address=10.2.0.0/16 gateway=10.51.50.102
add distance=1 dst-address=10.198.0.0/20 gateway=10.10.2.18
add distance=1 dst-address=10.198.80.0/20 gateway=10.10.2.6
add distance=1 dst-address=10.198.96.0/28 gateway=10.10.2.5
/ip service
set ftp address=10.10.0.0/16,10.2.0.0/16,public.26/32
set www address=10.10.0.0/16,public.0/27,public.26/32 disabled=yes
set ssh address=10.10.0.0/16
set api disabled=yes
set winbox address=10.10.0.0/16,public.0/27,public.26/32
/ip traffic-flow
set cache-entries=4k
/ppp secret
add name=weac password=
add name=roamer-2 password=roamer-2 profile=roamer-2 service=ovpn
add name=roamer-3 password= profile=roamer-3
add name=monte-ipc password=monte-ipc profile=roamer-4
add name=monte-hs-mrved password=monte-hs-mrved profile=lqpv-hd
add name=roamer-5 password= profile=lqpv-hd
add name=roamer-4 password= profile=roamer-4
add name=roamer-6 password= profile=roamer-6
add name=roamer-7 password= profile=roamer-7
add name=roamer-8 password= profile=roamer-8
add name=roamer-9 password= profile=roamer-9
add name=roamer-10 password= profile=roamer-10
add name=roamer-11 password= profile=roamer-11
add name=roamer-12 password= profile=roamer-12
add name=roamer-13 password= profile=maccray-hd
add name=roamer-14 password= profile=roamer-14
add name=roamer-15 password= profile=roamer-15
add name=roamer-16 password= profile=roamer-16
add name=blh-hd password= profile=blh-hd
add name=roamer-18 password= profile=roamer-18
add name=roamer-19 password= profile=bbe-hd
add name=roamer-20 password= profile=roamer-20
add name=roamer-21 password= profile=roamer-21
add name=roamer-22 password= profile=Roamer-22
add name=roamer-23 password= profile=roamer-23
add name=roamer-24 password= profile=roamer-24
add name=roamer-25 password= profile=roamer-25
add name=roamer-26 password= profile=roamer-26
add name=roamer-27 password= profile=roamer-27
add name=roamer-29 password= profile=roamer-29
add name=roamer-30 password= profile=blh-sc
add name=acgc password= profile=acgc
add name=roamer-31 password= profile=roamer-31
add name=Hutch-sc password= profile=Hutch-sc
add name=mrved-sc password= profile=mrved-sc
add name=bbe-sc password= profile=bbe-sc
add name=acgc-hd password= profile=acgc-hd
add name=mrved-internet password= profile=mrved-internet
add name=lester-hd password= profile=lester-hd
add name=nls-elem password= profile=nls-elem
add name=maynard password= profile=maynard
add name=yme-elem password= profile=yme-elem
add name=acgc-elem password= profile=acgc-elem
add name=acgc-sc password= profile=acgc-sc
add name=ort-hd password= profile=ort-hd
add name=blh-elem password= profile=blh-elem
add name=lakeview-elem password= profile=lakeview-elem
add name=monte-elem password= profile=monte-elem
add name=gsl-elem password= profile=gsl-elem
add name=gsl-sc password= profile=gsl-sc
add name=bold-sc password= profile=bold-sc
add name=bbe-hd password= profile=bbe-hd
add name=hutch-ms password= profile=hutch-ms
add name=bold-elem password= profile=bold-elem
add name=kennedy password= profile=kennedy
add name=lp-elem password= profile=lp-elem
add name=hutch-park password= profile=hutch-park
add name=bbe-elem password= profile=bbe-elem
add name=murdock password= profile=murdock
add name=kennedy2 password= profile=kennedy2
add name=neil password=neilbold1314* profile=Neil
add name=raymond password= profile=raymond
add name=raymond2 password= profile=raymond2
add name=raymond5 password= profile=raymond5
add name=monte-sup password= profile=monte-sup
add name=roamer-32 password= profile=Roamer-32
/routing bgp peer
add default-originate=always name=T1 remote-address=10.98.0.1 remote-as=6167 \
    ttl=default
add default-originate=always name=T2 remote-address=10.98.0.5 remote-as=6167 \
    ttl=default
/system clock
/system identity
set name=LCTN-FW
/system logging
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
add disabled=yes topics=firewall
add disabled=yes topics=bgp
add topics=ipsec
add disabled=yes topics=ovpn
/system ntp client
set enabled=yes primary-ntp=65.19.178.219 secondary-ntp=198.60.22.240
/system ntp server
set broadcast=yes broadcast-addresses=10.10.1.1 enabled=yes multicast=yes
set cpu-frequency=1200MHz memory-frequency=1066DDR
/system scheduler
add allow-address=10.10.0.0/16 interface=ether1
bump
The problem was resolved by specifying the outbound interface for NAT
