Hello everyone,
I’m new in this forum and I hope you can help me. For a while I started scripting. I have got scripts for two Mikrotik routers which are connected to each other via VRRP. As you can see one router is used as a gateway the other one is used as backup device. The export scripts on the gateway work fine with the scheduler. Last time I tried to run them manually. The logging said the scripts where running but nothing happened. So there was no error message in the log. After a few minutes of waiting I tried to kill the jobs but the killed jobs disappeared for 1 second and appeared again. The job remove command for the terminal didn’t work too.
I didn’t find something at google so I hope you can help. I am not able to restart the gateway router because even a short downtime would cause high costs for the enterprise I work for.
Thank you!
