Hi All,
i’m not able to access my Router from WAN, no ping, winbox, ssh, http and telnet.
even from my internal network i am not able to access my router through the WAN interface, i can only access it by using my LAN IP.
firewall filters all clean and accept any request from the internet.
i upgrade also to the latest firmware.
any suggestion
thanking you in advance.
If you’re 100% certain of this, then the only other place I can think of would be in the IP services configuration, you can specify a list of IP addresses where connections are allowed to come from.
Almost certainly, though, there’s an issue in the firewall area - be it due to filter rules, or a glitch in a load-balancing configuration in the mangle table / policy routing.
