not apear wlan in wireless table
hi
i have two metal2SHpn and bote of this metals dont have wlan interface.i install many os,reset to default,use netinstal for solve problem but it dont work.
pls help.thanks forall
Check System → Packages and see if the wireless package is disabled.
Is your problem solved?
hi
thanks foryour answering.i check this and wireless not disabled in system package.how can i install wlan driver again in this metal.and may be this solve problem.
thanks alot
No Problem, Here are the links that show how to re-install/ upgrade the software:
http://wiki.mikrotik.com/wiki/Manual:Upgrade_RB
http://wiki.mikrotik.com/wiki/Manual:Netinstall
You can install all packages drag en drop this in the window files and reboot.
See than in “system” “packages” if “wireless” package is installed
