Firewall Raw is not functional.
DNS is enabled as “DNS cache” on Mikrotik ver 7.14.x and 7.15.x.
Now anyone can use my DNS.
The firewall for the sit works but the dns blocking does not.
Is something wrong or just the version.
It has DNS cache in several places. And it’s becoming a big problem.
0 dns 192.168.0.0/16 1970-01-02 00:47:41
1 dns 10.0.0.0/8 1970-01-02 00:45:21
;;; google
2 dns 8.8.8.8 1970-01-02 00:45:27
3 dns 176.103.130.130 1970-01-02 00:45:34
;;; tucows.com
4 dns 1.1.1.1 1970-01-02 00:45:40
;;; open neco
5 dns 208.67.222.222 1970-01-02 00:45:46
;;; dns9.quad9
6 dns 9.9.9.9 1970-01-02 00:45:58
;;; cina alibaba
7 dns 114.114.114.114 1970-01-02 00:46:04
;;; vodafon
8 dns 31.30.90.1 1970-01-02 00:46:10
;;; vodafon
9 dns 31.30.90.2 1970-01-02 00:46:25
;;; google
10 dns 8.8.4.4 1970-01-02 00:46:56
;;; cina alibaba
11 dns 8.208.8.0/24 1970-01-02 00:47:12
;;; open neco
12 dns 208.67.220.220 1970-01-02 00:47:18
13 dns 62.168.9.230 1970-01-02 00:47:23
;;; hwclouds-dns
14 dns 94.74.74.175 1970-01-02 00:47:29
;;; dnsmob3.o2isp
15 dns 160.218.161.60 1970-01-02 00:47:35
;;; o2isp
16 dns 194.228.211.33 1970-01-02 00:47:56
17 dns 172.16.0.0/16 2024-09-16 16:36:43
Did you thoroughly think about what this rule does?
It says:
if dst-port is 53
AND
if protocol is UDP
AND
if src-address is not member of list named dns
AND
if dst-address is not member of list named dns
THEN
add dst-address to list named “dns!!!”
(I’m assuming you’re posting config as-is, not adding some emotional state of yours)
And I’m not going to think how these rules apply to DNS traffic you would like to allow and how it applies to traffic you want to prevent. And if address-list naming is appropriate at all. But if rules are not constructed exactly the way they should be, then they will not get executed.
According to packet flow, prerouting is executed before DST-NAT … which means that for packets, originating from internet, dst-address won’t be one of your LAN addresses, it’ll be your public (WAN) IP address for connections, originating from internet. Which means that these two rules won’t trigger.
I have hard time understanding what exactly doesn’t work the way you expect … which is the reason I didn’t react to your initial post. The only reason I reacted to your second post is that the wording of it indicates that you somehow blame Mikrotik or forum members for your setup not to work according to your expectations (which are, as I already wrote, hard to read from your initial post).
Mr. MKX. My language is not English. I just wrote here that there was a change. And mikrotik stopped throwing me unwanted DNS requests.
I didn’t mean to offend either you or the mikrotik.
I’m fine now, and if someone is using something similar it’s their fault.
Yes, there is IP/NAT I have LTE 4g network and the operator does not put a fixed ip on the router.
Have a nice week.
