when I try to add and edit a Device at map of net, the processor climbs to 100% of their use. Only happens with Windows XP to Vista works properly.
Someone has any idea of what may be happening
I’m using the dude on Windows XP Pro (service pack 3) with no problems.
Have you tried the usual, uninstall-reinstall etc or does the dude generate any error box for you?
I’m also using Dude on XP SP3. Actually, seeing how unpopular Vista is, I guess most people use Dude on XP SP3. No problems
Ohsnap, vistaids, now with 10% more fail.
In other notes, i use the dude fine with Ubuntu v8.04 only issue I ever have is with winbox itself, copying text to and from boxes and using the copy and paste buttons in the file window (which I didn’t really expect to work anyway)
Also works fine on Mac OSX with just the small issues same as ubuntu
