i have 2 office, 2 different provider and ppp type connection - pptp and pppoe.
router1 (rb3011 //pptp //6.40.55) not create automatic rule in mangle, but i ticked “change tcp-mss = yes” in PPP profile (1 years ago - that rule worked, but router was rb451)
router2 (hex lite //pppeo //winbox 6.34.2) create correct rule in mangle - 1 for in-interface and 1 for outinterface
if i`m not create rules in mangle - internet not work correctly ![]()
ok, maybe your PPPoE client is configured with the wrong MTU.
if you use an ethernet port with MTU set to 1500, your PPPoE client shall have 1492 byte MTU. (PPPoE + PPP header together are 8 bytes)
/interface PPPoE-client set 0 mtu=1492
this way routerOS will be able to figure out the MSS size automatically and adjust it as needed.
