soho
1
When I try to Export the DUDE is displayed the message “not enough free space available”.
As you can see the image but there is space, because I’m using a secondary media for the Dude.
In menu FILE, appear 0 byte for Dude… I’m not understanding.
The Dude is installed on a Mikrotik ROS x86 version 3.28.
Any tips?
normis
3
what are you trying to export, can you show us a screenshot of that too ?
soho
4
I’m trying to export the settings of the Dude. See image attached.
Find the syslog folder and clear out the logs then do an export. Change the settings for syslog and don’t save as much…
soho
6
thanks sweetdude, but not resolved … erased everything that was in the Syslog and I could not export. The same error is show.
Yeah that is crazy
I am not running ROS so I can’t do any testing… bleh.
Make a script to copy the dude folder to another folder?
soho
8
not understand … copy to another folder, why?
Oh that would be another way to make a backup… Just a complete copy of the original folder.
