I have a RB3011 as my modem/router.
Internet comes through the sfp1 port via Vlan 300. With dhcp client enabled on Vlan 300
But my wired speeds are around 65MB per second so around 500 to 600 mbit. Sometimes fast.com gives 800 mbit but at least no speedtest comes to 1gbit. With the original modem I would get speeds of around 900 to 950 on fast.com and speedtest download. So there must be something i’m missing.
My config is as followed:
add admin-mac=64:D1:54:F4:F3:C3 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=ether9 ] speed=100Mbps
set [ find default-name=ether10 ] poe-out=off speed=100Mbps
set [ find default-name=sfp1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
auto-negotiation=no
/interface vlan
add interface=sfp1 name=vlan300 vlan-id=300
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=DHCP_LAN ranges=192.168.1.100-192.168.1.199
add address-pool=DHCP_LAN disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add interface=vlan300 list=WAN
add address=192.168.1.1/24 comment=defconf interface=bridge network=
192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
vlan300
/ip dhcp-server lease
add address=192.168.1.201 mac-address=B8:27:EB:F1:F4:A9 server=defconf
add address=192.168.1.202 mac-address=70:AF:24:12:AC:4C server=defconf
add address=192.168.1.203 mac-address=B8:27:EB:DA:C0:B8 server=defconf
add address=192.168.1.204 mac-address=D0:50:99:8E:49:B3 server=defconf
add address=192.168.1.200 mac-address=00:11:32:A1:4B:25 server=defconf
add address=192.168.1.22 mac-address=00:D9:D1:CD:06:27 server=defconf
add address=192.168.1.23 mac-address=00:0C:29:23:0D:34 server=defconf
add address=192.168.1.210 mac-address=64:00:6A:51:0E:2D server=defconf
add address=192.168.1.21 mac-address=00:04:4B:CF:26:9E server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.200,8.8.8.8
gateway=192.168.1.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router.lan
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=dst-nat chain=dstnat dst-port=443 in-interface=vlan300 protocol=
tcp to-addresses=192.168.1.200
add action=dst-nat chain=dstnat dst-port=80 in-interface=vlan300 protocol=tcp
add action=dst-nat chain=dstnat dst-port=5001 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=2202 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=6690 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=1723 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=3478 in-interface=vlan300 protocol=
udp to-addresses=192.168.1.20
add action=dst-nat chain=dstnat dst-port=8443 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=8080 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=8880 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=8843 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=9443 in-interface=vlan300 protocol=
tcp to-addresses=192.168.1.210
add action=dst-nat chain=dstnat dst-port=902 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=25565 in-interface=vlan300 protocol=
tcp to-addresses=192.168.1.23
add action=dst-nat chain=dstnat dst-port=25566 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=25567 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=25568 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=22 in-interface=vlan300 protocol=tcp
add action=dst-nat chain=dstnat dst-port=9000 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=8085 in-interface=vlan300 protocol=
add action=dst-nat chain=dstnat dst-port=32400 in-interface=vlan300 protocol=
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/lcd
set backlight-timeout=never default-screen=interfaces
/lcd interface pages
set 0 interfaces=sfp1
/system clock
set time-zone-name=Europe/Amsterdam
/tool graphing interface
add interface=bridge
add interface=sfp1
/tool mac-server
/tool mac-server mac-winbox
