Not getting Bios Screen
Trying to Install Router Board thru NetInstall.
After booting its gives a Screen.
RouterBOOT booter 2.7
RouterBoard 133C3
CPU frequency: 175 MHz
Memory size: 16 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
i am NOt Getting BIOS screen after pressing . What to do.
I have also tried with as well as <DEL+BACK SPACE>
Still NOT Working.
What to Do.
you can change settings in here too:
http://www.mikrotik.com/testdocs/ros/2.9/system/routerboard.php
you can also set a longer boot delay
NORMIS,
Actually i LOSt the password so tring to install OS thru it. Now i have Installed thru NetInstall. But Again I am NOt getting the Screen Again.
Trying bootp Protocol…
Any other Serial Terminal
Try to disable hardware flow control, try with another null modem cable.
test the same null modem cable with another RB133c board, if you are to login into BIOS.
