"not responding" - f.k.a. SA Query timeout
What means “Google Cast enabled devices”? What kind of devices are these? You mean this all happens while casting e.g. Youtube from Android phone to your Android TV?
Using the following devices Google Nest Audio, Google Nest Mini, CCwGTV(4K), Harman Kardon Soundbar, Xiaomi MI Smart Speaker to stream content from Spotify, Netflix, MAX etc.
Thank you for asking, but I don't think it will shed any new light to this issue sharing a bare minimum device "default" configuration.
That type of configuration should "just work". And it does with RoS 7.14.3 and older.
@mndtrp: Have you tried explicitly disabling management-protection? It’s “allowed” by default for WPA2 but can be set to “disabled”. The only relevant thing about Chromecasts that I can find is linked to protected management frames. Has mikrotik support confirmed to you that they tested the issue with some Chromecast devices connected to wifi?
P.S. I have the same problem as you (lots of Chromecast devices, nothing never than 17.4.3 works) but no means to easily test different ROS versions.
In addition to what I wrote here: https://forum.mikrotik.com/viewtopic.php?t=198736&start=300#p1121487
When testing only 2 devices connected at a given time (WiiM Mini and Moto Edge Fusion 30) I realized, that the issue does not manifest when both devices are on different radios, that is WiiM Mini is on 2GHz and Moto on 5GHz, then it is perfectly stable.
Moto gets frequent random SA Query timeouts ONLY when both devices are on the same radio, and does not matter if 2G or 5G.
Not sure what to make of it, but to me it seems it cannot be some WiFi setting causing it, if if is abosutely fine when the clients are separated on different radios (with exactly the same WiFi settings) and fighting each other when connected on the same radio.
Maybe someone else knows more how exactly this works in ROS, from my point of view this must be something on driver or even HW level.
Yes, I tested explicitly disabling management-protection with RoS 7.17rc2 and supplied supout.rif’s to the ongoing support ticket I have with Mikrotik.
There was no difference in behavior with or without management-protection.
Starting to lose hope. As I opened the ticket late 2024 with a lot of back and forth testing multiple settings that Mikrotik support recommended. But now it has been quiet from support. No updates from their side for weeks and there are no relevant fixes in the current 7.18beta-rc releases.
What about putting the Chromecast devices on a separate virtual SSID?
I have tried that. In addition to separate master interfaces 2.4 and 5. Same behavior.
This is also known to MikroTik support.
The same issue http://forum.mikrotik.com/t/hap-ax3-random-wireless-disconnects/176477/1
Has anyone tried stable 7.18 yet? Same behavior or fixed? Please share your result.
Same behavior. See the link in the post above yours.
I have same issue on MikroTik hAP ax^3 with ROS 7.18 and Samsung Galaxy S24 Ultra. With ROS 7.14.3 it works fine.
7.19beta2 appears to be worse for me
I have the same router and smartphone, the wireless connection is very stable with 7.18.1!
Post your configuration…
I agree. And I didn’t have any problems to begin with!
Roaming on 7.19beta2 seems to be broken for me. Including 2.4Ghz stability (I think?)
Created a supout and attached it to SUP-181003.
Here’s my WiFi 5G configuration. Nothing extraordinary:
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.antenna-gain=5 .country=Ukraine .mode=ap .ssid=SnakeNet_5G disabled=no security.authentication-types=wpa2-psk,wpa3-psk
On 7.18 I get periodically “connection lost” messages. The issue is random, the phone can stay connected for several hours, or disconnect several times in one hour. As I said on 7.14.3 it works fine, no disconnections.
What device are you using? Setting gain manually should only be used for devices where antenna can be detached.
Otherwise you should use TX Power and leave gain to default.
It's MikroTik hAP ax^3, currently with 7.14.3. I didn't enter antenna gain manually, it came from default config.
I think you need to read what is DFS (Dynamic Frequency Selection) and after reading it you will come to the conclusion that when you live in Ukraine, you need to turn it off.
