¿Not shutdown on RB1100AHx2 ?
Regards,
I just bought this RB yesterday…
When i try shutdown ( using winbox, telnet, ssh.. ) i disconnected, but, FAN RPM its 100% and, NEVER shutdown… I need unplug power cable…
¿Its a software bug? ¿Or hardware?
Thanks!
Edit:
For add a video playing this issue
http://www.youtube.com/watch?v=k9xX1eh3DW8&list=UUheKSAT3yVOkTzHd5VSbVyA&index=1&feature=plcp
Anyone?
is FAN working normally when you are running RouterOS?
what version of RouterOS you are running, try to install newer if it is not the latest using netinstall tool.
Yes, fan working normally when running RouterOS. When shutdown, fan RPM its higher, about 100% RPM, and never shutdown… have got unplug AC power
Version
-RouterOS 5.12
-RB firmware 2.39
router does not have ACPI calls, so when turned off, you have to unplug it to cut the power.
Now understand…
Thanks for support :slight_smile:
