I have a routerboard on top of a tower that has either a SR9 or XR9. Unfortunately, I’m not sure which card it is. Is there a way to determine this from winbox without climbing the tower?
Eric
Eric
The easiest way to tell is to open the wireless interface and goto the general tab..
Wireless (Atheros AR5213) is SR9 and
Wireless (Atheros AR5413) is XR9.
This won’t work in all situations.. for example it would be difficult to determine an XR2 from an XR9 using this method..
-Gerard
Gerard,
Thanks, that did the trick.
Eric
