not sure
need advice on the following issue pls guys
how to link rb411 to netgear dgn2200 and be able to access the internet the link part i got but the routing i don’t
you can simply put ether1 and wlan1 into a new bridge, everything will work just fine.
first create bridge:
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=65535 max-message-age=20s mtu=1500
name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
put wlan1 into bridge1:
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none interface=wlan1
path-cost=10 point-to-point=auto priority=0x80
put ether1 into bridge1:
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none interface=ether1
And dont forget to set wlan1 to work as client wds, if you connect wirelessly to your netgear. In WDS set WDS mode Dynamic
thank you very much
and dont forget to give me karma !!!
